Ignition Switch
  • 54Police74
    • Jun 2012
    • 13
    Ignition Switch
    Can someone assist me with the positioning of the contact roller when in the OFF position? A photo with the switch viewed showing the contact roller would be helpful.
    • 4789
    When in the off position the roller is perpendicular to the mounting legs.
      • 8243
      This may or may not be the same as your switch, 54,
      But it might help others,
      • otis71
        • Jul 2015
        • 597
        I replaced the contact bar and contact plate in a switch with original NOS parts. The spring appeared more than adequate but I still have a small dead spot when turning on the headlight. Also lubed it sparingly with dielectric grease. Any ideas why?
          • 4789
          OEM or aftermarket contact bar? Some AM are smaller diameter and basically junk. And are the rivets tight on the contact plate?
          • droptopford
            • Jan 2010
            • 360
            Not to minimize your issue but honestly, I never had an ignition switch that didn't have a small 'dead spot' between Run and Lights.
            • otis71
              • Jul 2015
              • 597
              Both the plate and bar were nos oem parts
              • 54Police74
                • Jun 2012
                • 13
                Rubone, thank You for quick response. My assembly of the switch was as you suggested. After tracing the wiring following the diagrams(many times) I have the following issue's. In off position tail lamp is light, #2 position gen & oil lamp light, tail lamp off, #3 position gen and oil lamp light and horn functions. This is a police model and I'm using a 49-54 wiring diagram(standard Equipped) with new replacement wiring kit.
