1964 FLH Windshield Fitment
  • Iacovos
    • May 2012
    • 208
    Hello everyone,
    I have a question regarding the fitment of a windshield to a 1964 FLH WITH passing lamps.
    Are these straight brackets also needed when the bike has the passing lamp brackets installed?
    Please see attached pictures
    • 4790
    No, one replaces the other.
    • Iacovos
      • May 2012
      • 208
      GREAT
      Thank you very much Rubone
      • Iacovos
        • May 2012
        • 208
        Hello again! I have another question. I got really confused.
        Please refer to the attached pictures.
        To fit the spotlight bracket on one side you need the two bolts PLUS the spacer on top (please see picture attached from the parts file.
        But how do you install the bolt below? Without any spacer? Just the bolt and a lockwasher? Then the bracket will touch the Nacelle.
        The 64 I have here has three washers (see picture) which obviously is wrong but I can see that without the spacers/washers the bracket will touch the Nacelle.
        Please assist
        THANKS
          • 4790
          Since you do not have turn signals on it the washers are fine, otherwise the signal bracket acts as a spacer on the lower bolt between the nacelle and bracket.
          • Iacovos
            • May 2012
            • 208
            Thanks a lot Rubone
            Not planning to use turn signals
            So will leave those washers in place
