Offset Springer - Fork Spring Rod Bushing Retainer
  • gitguy
    Middle-of-the-road Member
    • Nov 2009
    • 254
    Originally posted by duffeycycles View Post
    Robbie's right,look at the headlamp page, 1954 BT parts book
    looks like it comes from top down
    I think we are discussing two different things here. The only reason I am interested in this topic is because I am at the point on my 48 EL project where I am installing the the headlamp and associated parts and would like to get it right.
    The bolt in question is the one that JGBrown showed in his original post. This one:
    Part # 4000/066 is the bolt that fastens the headlamp bracket to the top of the fork, here:
    Again, I cant seem to find the reference for the bolt that goes here:
    Thanks gents!
      • 4791
      Thanks gents!
      As I posted, it is 4000. Now I'm done here.
        • 2044
        Sorry,I get it now ! bolt not shown anywhere. I still agree with Robbie 4000 / 066
        • jgbrown59
          • Jul 2008
          • 83
          Is this the actual parts listing reference to the 4000/066 bolt for the retainer?
          • dukekleman
            • Jul 2022
            • 599
            Yes, that is the fastener Robbie is referring too.
            there is quantity (2) required as shown in the parts book. One goes on the handlebar mount tab and the other goes on the spring bushing retaining plate.
            IMG_20231206_175155600.jpg Technical writers make errors back then and nowadays as well. Today, most service literally is electronic so revisions are easier, verse paper revisions years ago that were supposed to be added as an insert. Regardless, yes it's not clear with the tech writers layout design and omission in areas but Robbie is correct, use part number 4000, two times.
            Hope this helps,
            Duke
            • gitguy
              • Nov 2009
              • 254
              Hope this helps,
              Duke
              Thanks Duke.
              • gitguy
                • Nov 2009
                • 254
                I just asked for a reference in the parts book and apparently you couldn't find one all you could respond with was "it is 4000 now I'm done here". Last time I checked responses were voluntary. No need to get smarmy.
                Duke came up with a plausible explanation. Thank you sir.
