does anyone know where the taillight wiring exits the rear fender.
56 panhead rear fender wiring
On mine From memory(I am not out in shop at moment) on the moveable end part of fender there is a closed metal channel under the tail light, then a metal coil/spring type conduit spanning the hinge area that goes to an open type U channel with metal tabs bent over to hold wire in. This channel runs in an arch along the side of the fender that exits the fender through a hole near the chain cutout. If no one else chimes in I will go out tomorrow and verify what I just said.
That is a factory photo.Originally posted by duffeycycles View PostHey Chris,that shows a loom all the way to the junction box.Were some with a shorter loom & exposed wire for part of that distance? I ask because some wire harnesses made have shorter loom for this area, not the full length to the coil junction.Be sure to visit;
