56 panhead rear fender wiring
  • shovelheadstan
    • Nov 2017
    • 45
    does anyone know where the taillight wiring exits the rear fender.
  • upsrod
    • Feb 2010
    • 320
    Into the taillight.
    • shovelheadstan
      • Nov 2017
      • 45
      out of the fender towards the battery
        • 4791
        What are you dealing with? A repop fender? Factory fenders have an exit hole in them that is pretty self explanatory.
        • shovelheadstan
          • Nov 2017
          • 45
          Taiwan tedd repop
          • camsaure
            • Nov 2009
            • 135
            On mine From memory(I am not out in shop at moment) on the moveable end part of fender there is a closed metal channel under the tail light, then a metal coil/spring type conduit spanning the hinge area that goes to an open type U channel with metal tabs bent over to hold wire in. This channel runs in an arch along the side of the fender that exits the fender through a hole near the chain cutout. If no one else chimes in I will go out tomorrow and verify what I just said.
            • camsaure
              • Nov 2009
              • 135
              Oops sorry I should have mentioned, mine is a 50 and my other a 49 is the same. But I would think 56 would be the same.
                • 4791
                If you look closely you see the wire comes out just below the frame rail, then is routed along the inside of it to the terminal box. The ends of the clip holding the wire are visible . This is a '54 but '56 is the same.
                • shovelheadstan
                  • Nov 2017
                  • 45
                  Got it thanks for the help
                      • 2044
                      Hey Chris,that shows a loom all the way to the junction box.Were some with a shorter loom & exposed wire for part of that distance? I ask because some wire harnesses made have shorter loom for this area, not the full length to the coil junction.
                        That is a factory photo.
