Fuel Cutoff/Reserve Tank Rod Question
  • craig (DE)
    • Oct 2010
    • 344
    Originally posted by Hollywood View Post
    I replace the spring, washer and seal with a piece of 1/4 fuel line cut to about a 1/4 inch length. I've used this method for decades.
    [ATTACH=CONFIG]15238[/ATTACH][ATTACH=CONFIG]15239[/ATTACH][ATTACH=CONFIG]15240[/ATTACH][ATTACH=CONFIG]15241[/ATTACH]
    How did you get your fuel rod to go through the 1/4" line? Mine is way to tight to squeeze through the rubber.
    Craig (Delaware)
    Delaware Bay Chapter
    Perkiomen Chapter
    AMCA Member #1011
      Maybe he carves a bit, Craig!
      Fuel lines have fiber reinforcement.
      Neoprene roofing rubbers have a 3/16" bore which stretches easily to the 5/16" rod, and expands nicely to fill the bung.
      (I think I'll stash mine.)
      Not gonna push my vitons, Folks,...
      ..because I'm overloaded when I should be shutting down.
      • craig (DE)
        • Oct 2010
        • 344
        Thanks Cotton! I know this is an old thread but there is no way my shutoff rod will squeeze through a 1/4" fuel line.
        Craig (Delaware)
        Perkiomen Chapter
        AMCA Member #1011
