Fuel Cutoff/Reserve Tank Rod Question
  • 60pan
    • Feb 2012
    • 11
    My 60 Panhead Fuel Rod has just messed up. It is an original, and the rod no longer stays up in the "Reserve" position. I noticed a broken spring under the knob.
    I was going to look for a kit to replace the spring, but I have also had problems with the rod not shutting off the gas flow completely so I wanted to fix everything at the same time.
    Is there a diagram or schematic of the fuel rod assembly somewhere that I can look at to figure out how the valve and fuel rod works?
    I suspect that without the spring, there will be no "Reserve" function of the fuel rod, correct?
    Thanks for any help you can give me.
    • 2044
    the knob is the top ,next is the seal cap ,spring,washer,& seal-the seal sits in a taper and the spring pushes down on the seal wedging the seal against the rod to stay up on reserve.The seal and spring need to be in good order.The shutoff is at the bottom--many people are replacing the whole unit with one from Carl's Cycle ,with a Peek[plastic]tip at the shutoff
      • 2024
      You've got 2 separate problems here. The failure to stay in the lifted reserve position is caused by the broken spring and probably a worn sealing washer on the top and the leaking is caused by a worn seat on the bottom valve unit or possibly on the bottom of the rod itself.
      Jerry
      • billpedalino
        • Mar 2005
        • 1096
        The problem I have is how the top seal changes geometry after its installed and exposed to the 'gasahol' we now call fuel. The rod becomes very difficult to turn and lift soon after the tanks are filled ad the fuel is swirled around. There must be another material for this application!
        Bill Pedalino
        Huntington, New York
        AMCA 6755
          Bill!
          The original design depended upon the spring against the washer to expand a simple cork for a seal, and resistance.
          For over two decades now I have been removing the cork, washer, and spring, and replacing them with two common neoprene roofing nail washers.
          The fuel fattens them up just right.
          • billpedalino
            • Mar 2005
            • 1096
            Nice - I'll try that.....
            Bill Pedalino
            AMCA 6755
            • Sidehacker
              • Sep 2012
              • 235
              Two questions about the peek shutoffs.
              Are they sold by Carl's cycle?
              Do they look origional ?
              • vph-d
                • 1088
                I bought a couple of Carl's shut off rods. They are nicely cad plated, and look stock to me.
                VPH-D
                • Hollywood
                  • Mar 2011
                  • 223
                  I replace the spring, washer and seal with a piece of 1/4 fuel line cut to about a 1/4 inch length. I've used this method for decades.
                  • Lyle Manheimer
                    • Mar 2008
                    • 193
                    Carl's kit works well, looks stock. All parts are of top quality and everything is there for a complete rebuild and no more leaky fuel tap.
                    • Sidehacker
                      • Sep 2012
                      • 235
                      Thanks I ordered two, one for my UL and one for my FL. Thanks. I have been wanting a reliable shut off for thirty years. Glad someone finally designed one.
                      FNA
                        Sidehacker!
                        I just dress the shut-off rod on the lathe, and its good for another thirty years.
                        Takes five minutes.
                        • kurly
                          • Mar 2007
                          • 90
                          I tried to dress mine and it still seeped. I put one of Carl's in and starts great again and the garage doesn't stink anymore. I wish I had done it years ago.
                          Kurly
                            Kurly
                            Kurly!
                            You cut it with a lathe, or spun it in the drill press with emery?
                            Had to ask, sorry.
                            PS: With all due respect to Carl supplying a fine complete assembly, (and PEEK itself special to me), I still think the original metal, properly cut (its like a simple "45" on the toolpost to give a 90 degree point,..) will survive longer.
                            • billpedalino
                              • Mar 2005
                              • 1096
                              Hollywood,
                              The 1/4" hose trick has been working very well - thank you...
                              Bill Pedalino
                              AMCA 6755
