64 FL Compensating Sprocket Fit?
  • grollock
    • Feb 2013
    • 14
    I recently purchased a 64 FL that had a belt in the primary.
    I have located the parts needed to convert it back to a chain
    including a compensating sprocket. It seems that the sprocket
    shaft isn't long enough to accommodate the compensating sprocket
    without compressing the spring 1/2 inch to start the threads. Not easy.
    My Question Is: Was the sprocket shaft longer on models equipped with
    compensating sprockets from the factory? Thanks, Gary
  • BigLakeBob
    • 2768
    No the shafts were not longer. Can you post some pictures with measurements of the spring and nut? All pan parts and no shovel right? Bob AMCA#6738
    Bob Rice #6738
    • grollock
      • Feb 2013
      • 14
      Here are the pictures Bob. Thanks.
      • kg993
        • 263
        Does that nut have a grease fitting in the outer end? It is too short compaired to mine. The distance in picture #2 should be 2 1/4" plus a little. This is from a set stamped 55A.
        Kerry AMCA # 15911
        • BigLakeBob
          • 2768
          I would say the nut is incorrect or the length has been altered, it just looks too short. I agree with Kerry. Bob
          Bob Rice #6738
          • grollock
            • Feb 2013
            • 14
            I looked at a picture on J&P's website and the difference in length is quite obvious.
            Bob and Kerry, Thank you both for your help. Take care.
            Gary AMCA # 7334
            • Paul G Bergeron
              • May 2010
              • 166
              hi gary tried to call you left message on phone call pete thanks paul g bergeron 7989
