sdreat yoke clamp
  • dec241949
    • May 2011
    • 9
    sdreat yoke clamp
    Can someone tell me how the seat yoke clamps are to be installed on a buddy seat/t- bar. Bought a repro set and have my idea of how to install them but it doesn't seem to be right. Set consists of a 3/16 plate, a 3/16 upper clamp, the sprung steel lower clamp and two square headed bolts and nuts. Any help is appreciated! Mike
  • portagepan
    • Feb 2006
    • 580
    Palmer's resto book has some good pics. What year is your bike. Are you talking about the clamps to hold the helper springs? Mike
    • dec241949
      • May 2011
      • 9
      The bike is a 49 FL and I have Palmers book but it is hard to make things out. Right now I have the plate on top, the heavy clamp next and then the sprung steel clamp. All this is mounted below the seat T with the wing nut bolt in the rear hole, the shorter bolt in the next hole and a nut and bolt at the front holding the whole mess together but not going through the seat T. Sound right? Thanks! Mike
      • portagepan
        • Feb 2006
        • 580
        I think you have it right. It has been a while since I had one of that style assembled. I think the square head actually is kept form turning by a little flange, or something. The bolt heads all go on top. Now you have to make sure you have the right yoke, and fender clip. Mike
        • dec241949
          • May 2011
          • 9
          Thanks for your help. A buddy of mine also thought it was correct. Everything seems to work well---the helper spring yoke snaps in so I guess I'll call it good. Thanks again! Mike
          • cdndewey
            • Jan 2005
            • 438
            If memory serves me correct, it is the heavy clamp on top, spring plate underneath, and then flat plate on the bottom. I believe the bolt with the wing nut is the one closest to the opening.
              • Feb 2003
              • 5353
              A friend sent me this stuff when I was scrounging parts and pieces for my buddy seat.
              Cory Othen
              Membership#10953
              • Sargehere
                Member since 1972
                • Jul 2006
                • 971
                Thank you, Cory! As usual, you can be relied upon to provide the straight "skinny!" That official 1946 document leaves not a shadow of a doubt about how the question posed is to be answered. Thanks!
                Gerry Lyons #607
                http://www.37ul.com/
                  • Feb 2003
                  • 5353
                  No problem Sarge... If I've got the info, I'm happy to share....
                  Cory Othen
                  Membership#10953
                  • dec241949
                    • May 2011
                    • 9
                    Thanks Cory! The picture along with the reference arrows was very helpful. Mike
                      • Feb 2003
                      • 5353
                      You are most welcome Mike! I'm glad it was of some use to you.
                      Cory Othen
                      Membership#10953
