sdreat yoke clamp
    replied
    You are most welcome Mike! I'm glad it was of some use to you.
  • dec241949
    replied
    Thanks Cory! The picture along with the reference arrows was very helpful. Mike
    replied
    No problem Sarge... If I've got the info, I'm happy to share....
  • Sargehere
    replied
    Thank you, Cory! As usual, you can be relied upon to provide the straight "skinny!" That official 1946 document leaves not a shadow of a doubt about how the question posed is to be answered. Thanks!
    replied
    A friend sent me this stuff when I was scrounging parts and pieces for my buddy seat.
  • cdndewey
    replied
    Originally posted by dec241949 View Post
    The bike is a 49 FL and I have Palmers book but it is hard to make things out. Right now I have the plate on top, the heavy clamp next and then the sprung steel clamp. All this is mounted below the seat T with the wing nut bolt in the rear hole, the shorter bolt in the next hole and a nut and bolt at the front holding the whole mess together but not going through the seat T. Sound right? Thanks! Mike
    If memory serves me correct, it is the heavy clamp on top, spring plate underneath, and then flat plate on the bottom. I believe the bolt with the wing nut is the one closest to the opening.
  • dec241949
    replied
    Thanks for your help. A buddy of mine also thought it was correct. Everything seems to work well---the helper spring yoke snaps in so I guess I'll call it good. Thanks again! Mike
  • portagepan
    replied
    I think you have it right. It has been a while since I had one of that style assembled. I think the square head actually is kept form turning by a little flange, or something. The bolt heads all go on top. Now you have to make sure you have the right yoke, and fender clip. Mike
  • dec241949
    replied
  • portagepan
    replied
    Palmer's resto book has some good pics. What year is your bike. Are you talking about the clamps to hold the helper springs? Mike
  • dec241949
    started a topic sdreat yoke clamp
    sdreat yoke clamp
    Can someone tell me how the seat yoke clamps are to be installed on a buddy seat/t- bar. Bought a repro set and have my idea of how to install them but it doesn't seem to be right. Set consists of a 3/16 plate, a 3/16 upper clamp, the sprung steel lower clamp and two square headed bolts and nuts. Any help is appreciated! Mike
