[QUOTE=Steve Little;90060]If I can ask you a couple more questions on your frame.... Does your frame have the foundry mark on the big triangle of the left side of the neck.
If so, does it have a number below it. "Your pic is a bit dark in that area"
Triangle? No, the hallmark is in a square as on all 1936 and early '37 frames.
Does you left axle carrier have a Hallmark or number after the XE-7. Is the XE-7 correct way up or upside down.
Can't tell as I am in the house for the nite now
Is the intermediate backbone 7/8" or 1"
7/8"
7/8"
