Linkert M74B
  • Laurie
    Dingo
    • Jun 2021
    • 27
    Linkert M74B
    G'Day Folks
    Ive just finished my 41 Knuckle and am having trouble dialing in my M74B Linkert, motor is a fresh rebuild by a reputable engine builder who cleaned checked and re assembled the carb, the only way to get this to idle and run is to have the low speed needle out 41/2 turns and so of course it runs rich and fouls plugs, I have tried shutting off the high speed needle, no help,
    At the starting procedure with the low speed needle set at 3 turns out and the choke on 1 click starts and idles nice but as soon as you turn off the choke it stalls
    any and all help greatly appreciated
    cheers & Beers
    Laurie
    Originally posted by Laurie View Post
    G'Day Folks
    cheers & Beers
    Laurie
    Generally, Laurie,...
    If they wont run any way but over-rich, it means extra air is getting in some where.
    The very first diagnostic is https://web.archive.org/web/20250615...hleaktest.html
    Only after the manifold is absolute can we address the carb itself.
    • Laurie
      Dingo
      • Jun 2021
      • 27
      The very first diagnostic is http://virtualindian.org/11techleaktest.html
      Cheers Cotten, dont know why I didn't think of that! I'll do a leak test on the weekend.
      Thanks mate!
        • 2024
        My experience is that knuckleheads do not like M-74B's. They seem to prefer a M-35.
        • Laurie
          Dingo
          • Jun 2021
          • 27
          Ok I did a leak test using a plate similar to the http://virtualindian.org/11techleaktest.html (forgot I had 1) and no leaks,
          I should mention that the heads has had an O ring manifold conversion done.
          Jerry
          I have a '46 thats been running a M74B for the last 8 years no problems there.
            Ok I did a leak test using a plate similar to the https://web.archive.org/web/20250615...hleaktest.html (forgot I had 1) and no leaks,
            Jerry
            If your conversion doesn't leak, Laurie,..
            Its one in a thousand!
            (Forgive me but I must ask: You are using a regulated, constant air supply, right?)
            And I had great luck tuning M74Bs, even for EL Knucks. But then, everything else was in order....
            • dukekleman
              • Jul 2022
              • 596
              Laurie,
              I'd like to try and help by first asking if the spring collar is in place and installed correctly? Here's and image of a spring collar.
              Also I'd like to ask if the throttle disc is installed in the proper direction. It's important to have it installed correctly. If not, your idle circuit will not operate properly nor will it transition fuel correctly. Here's an image of a throttle disc. Note the bevel at the 6 o'clock position in the photo. This bevel needs to be located by the idle and transitional circuits in the correct manner to function as normal.
              Hope this helps,
              Duke
                Originally posted by dukekleman View Post
                Laurie,
                Hope this helps,
                Duke
                That reminds me of the time, Duke,..
                A recognizable international Indian personality (at least within the Indian zodiac) sent me his vintage-tricked brand-X M5 with shaved shafts for flow, for a re-fresh.
                The throttledisc was soldered-in backwards.
                He had run it righteously for years! If they weren't forgiving, they would never have become legendary.
                • Laurie
                  Dingo
                  • Jun 2021
                  • 27
                  Cotten
                  I'll have to admit that it probably wasn't regulated properly and therefore not constant as my regulator is pretty ordinary, so im going to buy another regulator tomorrow & try again
                  • Laurie
                    Dingo
                    • Jun 2021
                    • 27
                    Laurie,
                    Hope this helps,
                    Duke
                    Duke I'll check the carb tomorrow! Thanks Mate!
                      Cotten
                      As long as it was regulated, it should be sufficient, Laurie..
                      Its not about accuracy as much as constant supply, and fifteen psi is over-kill but prudent.
                      (Had to make certain you weren't using a tire pump, or worse yet, a Schrader valve upon the test plate like silly ebay offerings.)
                      Once again I must add, you have really beaten the odds!
                      • Laurie
                        Dingo
                        • Jun 2021
                        • 27
                        Cotton
                        I hope your right! will get back to you when ive tested again, quick question though whats the best way to make sure the valves are shut?
                        • dukekleman
                          • Jul 2022
                          • 596
                          Laurie,
                          I'm not sure if you asking about fuel valves or engine valves.
                          On the engine valves you can set the engine to TDC compression stroke. If you are doubting either Valve over lap verse compression stroke, remove your push rod cover retaining clip , raise the cover tube and verify that both pushrods spin freely with your fingers.
                          Valve sealing integrity can be verified by performing a cylinder leak down test.
                          Hope this helps,
                          Duke
                            Cotton
                            Simple, Laurie!
                            Just watch the regulator; It will rise and drop as motor valves open and close, then set it at about fifteen at its highest. Its all about the pressure differential, not holding pressure, and it doesn't matter what stroke its on.
                            Please remember that there will always be air passing around the intake stems and guides that is orders of magnitude greater than the leaks we seek. That's why a constant supply is required, and Schrader valves give false negatives.
                            (The valves on Chiefs never seem to shut completely at the same time!)
                            • Laurie
                              Dingo
                              • Jun 2021
                              • 27
                              So Cotton
                              Where do they usually leak from?and why? bad fitment or to big a gap for the o rings?
                              Cheers & Beers
