Linkert M74B
    • 2044
    They can leak in many places,one is the rivet that holds the inserts in the heads.Another is the inserts to heads around the threads.If you actually have o-rings it is not stock.Either stock or modified, any point in the system can have a leak.Carb to manifold etc.
      Like Duffey posted, Laurie,...
      Not only are there many common places to leak, some leak at "impossible" places (little 'blisters' of foam form at porosities after a half-minute or so, and yes, they do affect performance!):
      Those were 'plumber's' castings, but here's modern S&S O-ring leakers:
      Without bubbles such curses could never be cured.
      (Note the first two had been perforated with a port, shown here repaired,
      in a frustrated attempt at some better idea, because they were not diagnosed.)
      Note also that the manifold-to-carb connection cannot be bubble-tested, so please arbitrarily grind the manifold flanges to *flat*,,... because they never are!
      • Laurie
        Dingo
        • Jun 2021
        • 27
        yes mate the heads were modified before I got them to O Ring type manifold
        • Laurie
          Dingo
          • Jun 2021
          • 27
          Cotten
          hope to get at it tomorrow, but I will also flat sand the flanges Thanks for the advice!
          Cheers & Beers
          • dukekleman
            • Jul 2022
            • 596
            Laurie,
            If your carburetor body is warped more than 0.015" , I would suggest you straighten it out prior to sanding.
            This will minimize the material lost when sanding which aids in retaining thread depth.
            Hope this helps!
            Duke
              Like this, Duke?
              I found that 13 ft-lbs is enough to distort the flanges:
              One bright customer zipped two of his carbs on with an impact, and even broke the castings at the bushings!
              PS: A late note on the importance of assembly torque:
              When I honed bores clean, it was always torqued to a plate. If a disc is cut to that exact bore, it will not install to zero daylight unless the plate is re-applied, as if installed to a manifold!
              OEM discs seem to have been produced intentionally sloppy and undersized.
              • dukekleman
                • Jul 2022
                • 596
                Yeah, along those lines.
                Certainly over-torquing and heat are the culprit causing major failures.
                Duke
                  Duke
                  Where's the heat come from on a carb flange, Duke?
                  • dukekleman
                    • Jul 2022
                    • 596
                    Cotton,
                    Heat Transfer/soak from it's encapsulated environment.
                    most damaging rises seen after shutdown.
                      Cotton,
                      If your carb and manifold get hot enough to distort, Duke,...
                      They are on fire!
                      PS: Fastener stress alone is enough.
                      • dukekleman
                        • Jul 2022
                        • 596
                        It's the heat and torque combination that I mentioned earlier that does all the damage.
                        The torque applied correct or incorrect combined with the heat realign the metallurgy and cause issues, just like all other components in the engine and transmission. The term "green" , "seasoned" often get thrown into the conversation.
                        Once the initial run in has occurred , you'll always notice it doesn't occur like it did to the extent.
                        Hope this helps,
                        Duke
                          #27
                          Hope this helps,
                          Duke
                          We are talking cast steel and cast iron manifolds, Duke,...
                          Plus insulating gaskets to the bronze carb flanges.
                          Do you really think a couple of hundred degrees makes the flanges warp?
                          I will give vibration some credit!
                          But its the gaskets that give the flanges room to move with fastener stress.
                          (Bronze actually becomes more malleable when chilled, and 'brittle' when heated.)
                          PS: Aluminum manifolds warp the same way.
                          PPS: Shouldn't the carb/manifold junction be cooled by the incoming air, plus vaporizing fuel?
                          (I've heard legends that they could ice up!)
                          • dukekleman
                            • Jul 2022
                            • 596
                            #28
                            All metals and plastics change with heat, torque and vibration.
                            Cryogenics is another process used.
                            Once those parts have all been seasoned, they tend to hold their dimensions much longer. Unless you sand to much off and thin it down...
                              #29
                              You mean, Duke,...
                              Our half-century and older hardware ain't seasoned?
                              Even if it was kept outside?
                              PS: We all agree, seasoned or not, metal moves!
                              • dukekleman
                                • Jul 2022
                                • 596
                                #30
                                No the opposite, I mean it is seasoned. Now once they are straighten out, it'll stay in formation longer than it did way back when it was new.
                                Hope this helps,
                                Duke
