1945 FL Tank Badge and Shifter Gate
  • 50Panhead
    • Sep 2014
    • 87
    I'm working on getting this bike back up and running for a customer. The owner is in his 80's and his son will inherit it one day. It will most likely pass on to the grandson. The bike has a lot of history behind it. I do know that back in the late 1950's when the owner bought the bike it had been costomized and the tanks and fenders were chrome plated. The owner soon painted it black where it remains today.
    My Questing is about the tank badge and shifter gate. As I understand the shifter gate is correct for the year, but the tank badge came out in 1947. The tank is obviously made for the shifter gate but why would one weld the mounting bracket on the tank for a panhead tank badge? Or did Harley do something weird in 1945 as only something like 600 of these were made.
    This gallery has 2 photos.
  • Architect
    • Dec 2014
    • 283
    Not done by Harley, that was modified by a previous Owner. That shift gate is not stock. In 1947 they switched the shift drum, making you shift "forward" towards the front end of the bike. Looks like a 1946 and down tank with an aftermarket gate to allow for later style shifter drum. Which way do the numbers on the gate go?
    As far as the tank badges, if the tanks are real 1945, someone updated to the newer style. Basically they changed badges and likely the shifting pattern to be like a "new" bike. Post of pictures of the gate from above.
    • vph-d
      • 1088
      I agree with Architect, the factory offered emblem mounts back then for owners to "upgrade" their machines. The shifter gate is aftermarket.
      vph-d
      • 50Panhead
        • Sep 2014
        • 87
        Architect See attached. This might enplane the reversed lever on the transmission.
          • 4784
          That is an "Acme" brand shift gate and reversing lever. It was a kit offered to switch the shift pattern to get the lever forward in high rather than back where some riders found it interfered with their leg in high. The tanks were likely smooth sided with no emblems from new if ordered for a police unit. Many tanks were made smooth for PD and commercial sales.The later emblems are an add-on. Here is a pic of an NOS Acme gate. I also have a mid 40s UL tank with smooth sided and a later emblem added.
          If you look at many 40s era Police photos you will see many bikes without emblems and PD logos painted on.
            • 2032
            50 Panhead posted a factory kit to change shift pattern.here is another one IMG_0069_1.JPGIMG_0070_1.JPG
              • 8234
              You told me it was an "Atlas", Robbie!
              • 50Panhead
                • Sep 2014
                • 87
                Thank You, you guys are great! Herman
                  • 4784
                  Atlas is correct, just an early morning brain glitch. But I can always depend on Cotten to find fault so now he is all better.
                    • 8234
                    Try more coffee, Robbie.
                      • 4784
                      I don't drink Coffee.....
                        • 5950
                        you will have to look at the mount to see if is added on or factory.
