Finally wore out drive chain and sprockets and need to replace them. Any advantage to hot riveting vs cold? Also is tedd’s sprocket kit worth a darn? I also saw someone hawking an old Dixie nos one on eBay.
Rear sprocket replacement
Tags: None
I've installed over a dozen Dixie's, Chopsickle!
The rivets set nicely cold, if you properly press them.
(Chief drum shown; I have the HD OEM fixture for 45s if anybody needs it.)
I still have some Dixie sprockets in stock, and although *quality*, I see no clue that they are OEM.
....CottenAMCA #776
Checked the sprocket I bought 2 weeks ago, mentioned above, has Dixie tag made in Japan. Probably better than Taiwan nowadays. And no rivets, I was mistaken.Bob Rice #6738
Mine are from at least a decade ago, BLB,..Originally posted by BigLakeBob View PostChecked the sprocket I bought 2 weeks ago, mentioned above, has Dixie tag made in Japan. Probably better than Taiwan nowadays. And no rivets, I was mistaken.
And we can be certain Dixie had quite a variety over the decades!
Unless they say Eversure Auto Agency (Old Delhi), I wouldn't worry.
....CottenLast edited by T. Cotten; 02-09-2023, 03:19 PM.AMCA #776
Just ordered a couple Dixie sprockets. Heartened by the fact they are made in Japan. Prolly sunstars or JT’s, or whatever they wer called back then. Nice rig cotton ! I have a 40 ton press , but only hand anvils. I’m crossing my fingers that my drum won’t need to be redrilled. We’ll see here shortly.. thanks, all!
PBI Sprockets makes the 51 tooth and a 49 tooth rear Sprocket for 30 through 58.
made in USA chromoly. They come with the rivits..I have not used it yet but I have used their countershaft sprockets on my big twins. Somebody really needs to make a quality tapered shaft engine sprocket.
VTWINN is door stop material.
I use both USA made PBI trans and rear sprockets and have never had a problem. More expensive than the imported but worth it in my opinion.Originally posted by paddy View PostPBI Sprockets makes the 51 tooth and a 49 tooth rear Sprocket for 30 through 58.
Bob
I still need a few more used ones, Folks!
.... Cotten
PS: Chromed ones are too much trouble..AMCA #776
Well, with the help of a friend, I installed a Dixie sprocket onto a vtwin drum last night for practice. The provided rivets were made of an alloy that was softer than I expected, making the project a snap. The hand anvils used were from tedd’s and were fine. Today , I’ll check the runout and my work as the job was liquid inspired. Then, if everything looks good, I’ll cut it off and install on my oem drum. Fingers crossed!
And this gal was no help at all….
Contrary to the statement that they fit 30-58 they will not fit a 36EL.Be sure to visit;
