Rear sprocket replacement
  • chopsickle
    • Oct 2013
    • 34
    Finally wore out drive chain and sprockets and need to replace them. Any advantage to hot riveting vs cold? Also is tedd’s sprocket kit worth a darn? I also saw someone hawking an old Dixie nos one on eBay.
  • BigLakeBob
    • 2768
    Just bought one last week, does come with rivets. Have not tried it for fit, old Dixie stock.
    Bob Rice #6738
    • vph-d
      • 1088
      The Dixie sprocket is likely NOS surplus.
      vph-d
        I've installed over a dozen Dixie's, Chopsickle!
        The rivets set nicely cold, if you properly press them.
        (Chief drum shown; I have the HD OEM fixture for 45s if anybody needs it.)
        I still have some Dixie sprockets in stock, and although *quality*, I see no clue that they are OEM.
        • BigLakeBob
          • 2768
          Checked the sprocket I bought 2 weeks ago, mentioned above, has Dixie tag made in Japan. Probably better than Taiwan nowadays. And no rivets, I was mistaken.
          Bob Rice #6738
            Mine are from at least a decade ago, BLB,..
            And we can be certain Dixie had quite a variety over the decades!
            Unless they say Eversure Auto Agency (Old Delhi), I wouldn't worry.
            • chopsickle
              • Oct 2013
              • 34
              Just ordered a couple Dixie sprockets. Heartened by the fact they are made in Japan. Prolly sunstars or JT’s, or whatever they wer called back then. Nice rig cotton ! I have a 40 ton press , but only hand anvils. I’m crossing my fingers that my drum won’t need to be redrilled. We’ll see here shortly.. thanks, all!
              • paddy
                • Apr 2014
                • 219
                PBI Sprockets makes the 51 tooth and a 49 tooth rear Sprocket for 30 through 58.
                made in USA chromoly. They come with the rivits..I have not used it yet but I have used their countershaft sprockets on my big twins. Somebody really needs to make a quality tapered shaft engine sprocket.
                VTWINN is door stop material.
                • bobphd
                  • May 2008
                  • 99
                  I use both USA made PBI trans and rear sprockets and have never had a problem. More expensive than the imported but worth it in my opinion.
                  Bob
                  • dukekleman
                    • Jul 2022
                    • 596
                    I second Bob discoveries and have found the PBI sprockets to be consistent and work very well.
                      I still need a few more used ones, Folks!
                      .... Cotten
                      PS: Chromed ones are too much trouble..
                        • 6034
                        I also had a supervisor, Tom. I miss him every day.
                        • chopsickle
                          • Oct 2013
                          • 34
                          Well, with the help of a friend, I installed a Dixie sprocket onto a vtwin drum last night for practice. The provided rivets were made of an alloy that was softer than I expected, making the project a snap. The hand anvils used were from tedd’s and were fine. Today , I’ll check the runout and my work as the job was liquid inspired. Then, if everything looks good, I’ll cut it off and install on my oem drum. Fingers crossed!
                          • chopsickle
                            • Oct 2013
                            • 34
                            And this gal was no help at all….
                              Contrary to the statement that they fit 30-58 they will not fit a 36EL.
