Finally wore out drive chain and sprockets and need to replace them. Any advantage to hot riveting vs cold? Also is tedd’s sprocket kit worth a darn? I also saw someone hawking an old Dixie nos one on eBay.
Rear sprocket replacement
https://www.bmikarts.com/Rear-Wheel-...57_p_5624.html
Just bought one last week, does come with rivets. Have not tried it for fit, old Dixie stock.Bob Rice #6738
I've installed over a dozen Dixie's, Chopsickle!
The rivets set nicely cold, if you properly press them.
(Chief drum shown; I have the HD OEM fixture for 45s if anybody needs it.)
I still have some Dixie sprockets in stock, and although *quality*, I see no clue that they are OEM.
....CottenAMCA #776
Mine are from at least a decade ago, BLB,..Originally posted by BigLakeBob View PostChecked the sprocket I bought 2 weeks ago, mentioned above, has Dixie tag made in Japan. Probably better than Taiwan nowadays. And no rivets, I was mistaken.
And we can be certain Dixie had quite a variety over the decades!
Unless they say Eversure Auto Agency (Old Delhi), I wouldn't worry.
....CottenLast edited by T. Cotten; 02-09-2023, 05:19 PM.AMCA #776
Just ordered a couple Dixie sprockets. Heartened by the fact they are made in Japan. Prolly sunstars or JT’s, or whatever they wer called back then. Nice rig cotton ! I have a 40 ton press , but only hand anvils. I’m crossing my fingers that my drum won’t need to be redrilled. We’ll see here shortly.. thanks, all!
PBI Sprockets makes the 51 tooth and a 49 tooth rear Sprocket for 30 through 58.
made in USA chromoly. They come with the rivits..I have not used it yet but I have used their countershaft sprockets on my big twins. Somebody really needs to make a quality tapered shaft engine sprocket.
VTWINN is door stop material.
I use both USA made PBI trans and rear sprockets and have never had a problem. More expensive than the imported but worth it in my opinion.Originally posted by paddy View PostPBI Sprockets makes the 51 tooth and a 49 tooth rear Sprocket for 30 through 58.
Bob
I still need a few more used ones, Folks!
.... Cotten
PS: Chromed ones are too much trouble..AMCA #776
- 1 like
Well, with the help of a friend, I installed a Dixie sprocket onto a vtwin drum last night for practice. The provided rivets were made of an alloy that was softer than I expected, making the project a snap. The hand anvils used were from tedd’s and were fine. Today , I’ll check the runout and my work as the job was liquid inspired. Then, if everything looks good, I’ll cut it off and install on my oem drum. Fingers crossed!
- 1 like
Contrary to the statement that they fit 30-58 they will not fit a 36EL.Be sure to visit;
