How Many Knuckleheads still kicking
  • fxcw64
    • Aug 2019
    • 61
    #46
    Hey guys question
    If a Knucklehead has a UL # then it is a UL bottom(flathead) end with El or FL heads/jugs correct. True Knucks were only EL or FL ?
    Chris H- I have looked at your site and will continue Thanks
    "you gonna sit there and argue ......or FISH " Claude Leadbetter
      • 4790
      #47
      Originally posted by fxcw64 View Post
      Hey guys question
      No, not anywhere near correct. If it has a UL number it is almost 100% a restamp. The bottom ends are totally different and although it is possible to build such a hybrid, it is outside the ability of most and is not at all a common engine. The total existence could be counted on one hand.
      • fxcw64
        • Aug 2019
        • 61
        #48
        Wow Thanks Rubone you saved me from looking like a fool !! And you are correct I was mislead and that is straightened out with your help- the guy thought because the years were the same he had a knucklehead and gave me that # and I was confused since I had never known of a UL Knuck but figured it was the equivalent of people doing a Pan head/Shoval bottom.
        I guess I should have been able to figure this out since UL and WL are all either 74'' or 80'' correct ? and the early Knucks were 61'' cubic inches !!
        Plus I never saw the heads on said bike it was just a pic !!
          • 4790
          #49
          U and UL=74SV UH and ULH=80SV. W, WL, WLA, WLC, WLJ, WLH, G = 45. E, EL =61 OHV, and F,FL, FLH, FLE = 74OHV
          • Peter Cooke
            • Aug 2012
            • 572
            #50
            This might help.
            • fxcw64
              • Aug 2019
              • 61
              #51
              You guys are awesome !!! Thanks
              • 1950Panhead
                • Jun 2010
                • 343
                #52
                Hey guys question
                As Robbie says, knucklehead and UL and engines are completely different.
                A few four cam knuckles have been built.
                • fxcw64
                  • Aug 2019
                  • 61
                  #53
                  I can see now how wrong my original assumption was with the UL and EL hybrid --So for someone like me that sounds like alot of machine work putting heads on a bottom end that uses 4 cams instead of the single cam set up it came with!!!
                  I really can't wrap my head around that .....The angles seem all wrong WOW
                  Unless you just machine the covers to go over the ..........nope thats not it ------so do you just machine the UL heads to accept Knucklehead covers ???
                  Rubberband brain stretched to limits LOL -thats a headscratcher you got there 1950Panhead
                  • Kozy
                    • Feb 2004
                    • 129
                    #54
                    Look here for some insight.t http://victorylibrary.com/45MAG.htm
