Frame Restoration
  • Steve Little
    • Apr 2008
    • 915
    #31
    The oil tank was either, loose for a very long time or (and maybe also) the oil tank was the only thing holding the frame together at one time.
    The groove worn in from the battery/oil tank base, is about 1/16” deep.
    I think the same person might have forgotten to put the spacers under the oil tank before tightening it down.
    I decided it was junk and used one of ours.
    The guy that used to own this bike, probably had a jam jar full of washers and small parts that he would look at occasionaly, and scratch his head.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • Steve Little
      • Apr 2008
      • 915
      #32
      As previously mentioned in this thread, the decks had been badly ground by someone trying to get an engine back in this frame.
      To fix it, we bolted the CNC engine mount jig in the traditional mill, and freshened up the engine decks.
      Now it is ready to be bolted into the frame jig for re-assembly of the frame.
      Steve Little
      Australia.
      AMCA member 1950
      • Steve Little
        • Apr 2008
        • 915
        #33
        Cross over tube to engine mount
        Hi. Apologies for the low number of posts yesterday. Mondays are a busy day. See if I can get a few more posted today.
        When the brake crossover tube is installed in the rear engine mount to the correct depth, then it is time to tack and weld it. There is a critical length for the fitment. If it is not put in deep enough the overall length will fould on the brake cross over shaft
        I put two tack welds on opposite sides to stop it pulling. The mandrel is inside to help with alignment also.
        Steve Little
        Australia.
        AMCA member 1950
        • Steve Little
          • Apr 2008
          • 915
          #34
          Electrodes should be stored with the end sealed. Electrodes will soak up condensation in the air, and damp electrodes do not function properly.
          Dry/warm storage is the key storing electrodes. We go through a pack of electrodes in a couple of weeks but we still keep them dry.
          A open pack of electrodes left on a bench over a week end will get damp.
          Tip toe into the kitchen and grab the Clingwrap and wrap the electrode box to seal it.
          If she catches you, your on your own. You didn’t get the idea from me.
          Steve Little
          Australia.
          AMCA member 1950
          • Steve Little
            • Apr 2008
            • 915
            #35
            Toolbox bracket
            Time for the cheap toolbox bracket to come off.
            I am not sure why the manufacturer felt compelled to stamp this in the tool box bracket.
            It looks more like the poorly manufactured products that come out of Taiwan.
            Less than ideal appearnce on the welding
            Steve Little
            Australia.
            AMCA member 1950
            • Steve Little
              • Apr 2008
              • 915
              #36
              Once the toolbox bracket was removed. I started linishing away the weld and came across a straight line of a crack. Which then turned into a hidden tube repair. It was hidden by toolbox bracket.
              Maybe someone cut into the tube when they removed the original toolbox bracket.
              Further linshing revealed a rectangular repair which had been silver soldered in place. There is also a screw welded in the tube.
              Once the repair, and the welding style had been identified, we had to change our plans.
              The brazing weld made it impossible to do any other type of weld so we decided to cut this tube up further, and making our splice joint closer to the axle carrier.
              Steve Little
              Australia.
              AMCA member 1950
              • Steve Little
                • Apr 2008
                • 915
                #37
                Sleeve detail.
                The sleeve that we turned for the right side of the frame is the straight looking unit.
                It has a slight difference turned to the centre. One end is turned 0.833” and the other end is turned to 0.840”
                This was done to accommodate the different inside diameters of the two tubes.
                The second sleeve took a bit more work to fabricate. Not only did the two tubes have different size diameters but there was also a internal stiffener to accommodate.
                After turning it down, we then had to press the flat section that is in the tube for the inner primary relief.
                To do this we slit a piece of 1” inch tube down each side, and placed it over the section of the sleeve that was going to fit into that end of the join.
                Then we set up the die set that we use to press in this section of our replacement tubes.
                Cross fingers, and press.
                The sleeve fitted perfectly. You would think we do this for a living.
                Steve Little
                Australia.
                AMCA member 1950
                • Steve Little
                  • Apr 2008
                  • 915
                  #38
                  Welding
                  All fitted up ready for welding.
                  The white lines drawn on the tube, define the length of the sleeve inside the tube.
                  The tubes all fitted to the frame and are ready for welding.
                  The gap between the tubes is called the “penetration gap”.
                  The idea is that when the first weld is laid down, the weld will penetrate half way through the thickness of the sleeve and penetrate into each edge of the frame tube. This is called the root run.
                  Then the root run is wire brushed to clean any smoke fumes, slag, or impurities. Then a fillet weld is laid over the top. The fillet weld will penetrate into the root run and ensure a solid, full strength, X-ray quality weld.
                  The hollow sleeves will ensure that this join will happily move with the rest of the tube.
                  Steve Little
                  Australia.
                  AMCA member 1950
                    #39
                    Steve, this is a great thread but your giving them too much , too fast. Ya got to handle this like Disney did when we were kids. Leave ya frosting at the jaw until next Sunday at 7pm to find out if BoBo the Chihuahua makes it home, lol. Fantastic thread. Bob L
                    • Steve Little
                      • Apr 2008
                      • 915
                      #40
                      OK kiddies, today were going to Adventure land!!
                      Turn the lights off, and here we go.
                      Little Bobby, if you dont stop making finger shadows on the screen there's gunnu be big trouble.
                      Plug welds and root run finished.
                      Left side looks good aside from the shiney linnish marks. A light blast will make the frame look uniform and untouched.
                      Steve Little
                      Australia.
                      AMCA member 1950
                      • Steve Little
                        • Apr 2008
                        • 915
                        #41
                        1945-46 frame restoration 011.JPGSidecar lugs.
                        The circumferential welds and plugs weld are done and also the front engine mount.
                        Here we have fitted the rear engine mount, seat post, seat post cross brace, etc
                        When all the parts are fitted to the frame and then tightened to the jig, it is time to weld the seat post to the cluster.
                        Arc welded seat posts are welded around the top. The seat post sits about a 1/16” above the cluster.
                        The extra metal is then fused down to the seat post cluster.
                        This is called a fusion weld. No filler material is used during the weld
                        1945-46 frame restoration 012.JPG.
                        Steve Little
                        Australia.
                        AMCA member 1950
                        • Steve Little
                          • Apr 2008
                          • 915
                          #42
                          Rear trans mount fitted and aligned to the frame centre line. When its all tightened up, time for welding
                          Steve Little
                          Australia.
                          AMCA member 1950
                          • Steve Little
                            • Apr 2008
                            • 915
                            #43
                            Brake crossover support
                            Fitment of the brake cross over support has more importance than some frame restores and frame manufacturers give it.
                            If the brake crossover “support set” is placed too far in, it will pull the exhaust S bend in too close to the engine and it will also be to close to the supply oil line.
                            The exhaust S bend is already close to the crankcase, and most people have seen the lines worn into the right crankcase from the butted seam weld of the exhaust S bend
                            If the brake crossover support set is placed too far out, it will force out the exhaust S bend. This will make it too close to the brake lever pin.
                            1945-46 frame restoration 017.JPG.
                            The tool shown here ensures that the brake cross over support is set at the correct measurement.
                            No point looking for this tool on our web site. We have them, but they are not listed.
                            Ready for welding
                            Thats it for this week.
                            On monday I will be posting the pictures for line boring the brake cross over bushes.
                            When the restoration of this frame was complete, the engine decks needed cutting to bring them into factory specification. This is what Harley Davidson did with every frame that was completed off the assembly line.
                            I took some pictures of young Steve doing this proceedure on one of our mills. They will also be put up for your veiwing pleasure.
                            Steve Little
                            Australia.
                            AMCA member 1950
                            • Steve Little
                              • Apr 2008
                              • 915
                              #44
                              Reaming the brake crossover bush.
                              Pictured is our reamer for line reaming the two bushes in the brake crossover.
                              The shaft has tapered pilot bushing on both ends too ensure perfect alignment through each bush.
                              The drill has plenty of horsepower to cut through the brass bush.
                              Set up and ready to line ream.
                              Fit tapered pilot to end of reamer to align to centre of bush.
                              One cut and line ream is finished
                              Steve Little
                              Australia.
                              AMCA member 1950
                              • Steve Little
                                • Apr 2008
                                • 915
                                #45
                                Small ball hone with some Kerosene to take the high spots off the machining.
                                The shafts fits beautifully.
                                The way to tell a well fitted shaft, is to grab the end of the shaft between thumb and forefinger and spin it.
                                It should spin freely, and if you flick it between your thumb and forefinger it should spin a revolution by itself.
                                We cut the brake crossover bushes in our frames at 0.730” +0.001 -0.0005.
                                If your brake cross over shaft is bent, or if you have a aftermarket shaft, best to check the run out of the shaft between centres.
                                Harley Davidson made their brake shafts by putting a centre drill in each end and then rough machining them to size.
                                Then they were heat treated and then ground to final size.
                                Usually original shafts are good, but if your at a swap meet and the owner has his parts on a table, get down at eye level and slowly roll the shaft along the table.
                                I have seen a brand new aftermarket shaft, that had 0.015 run out which would mean they do not follow the same procedure as Harley Davidson.
                                If the brake crossover shaft does not operate freely, it will cause the back brake drag.
                                If the back brake drags, it will wear out the brake drum, brake shoes, and heat up the rear hub, to the point that the grease will run out and eventually destroy the hub.
                                Steve Little
                                Australia.
                                AMCA member 1950
