Hi.
We were just about to start the restoration of a 1945-early 1946 frame, when my co-worker (who is younger than me, and into all things computor) suggested that we should document how we work through our process and put it on a web forum.
We see a lot of butchered frames come through here, but this frame is going to be an easy job.
The top section of the frame is in pretty good shape but has a couple of small bends in the tubes.
The backbone and the intermediate backbone, and down tubes all have some slight bends from a head-on accident.
There is a pretty decent nick in the front of the neck and my guess is that the rear leg on a springer has been smashed back onto the neck. The part that sepperates the springs, has been smashed back into the frame at the upper section of the neck. This has bent the backbone downwards at the top engine mount.
And the 2 downtubes are bowed out toward the front.
For the record all downtubes and backbone tubes on any big twin frame should be straight...(except for the 1941 Bent style frame
I will add some more pictures later.
