Motor work on a 1916 H-D
    • 6008
    The depth of the finished bore about 6.81" with about 1/8" to 3/16" of relief before the domed head. From the edge of the spigot to the top of the dome head is about 7.4".
    • BigLakeBob
      • 2766
      Thanks Eric! I know how you like to do things yourself and I thought of a different approach that you could do, but that is deeper then the process I was going to suggest that you could do with your equipment.
      Bob Rice #6738
        • 6008
        A good friend said, 'don't ruin a good cylinder, by boring out a non-replaceable cylinder to fit a piston'. Okay, that's the ethos I have been working towards as an alternative to the proper (expensive) route of getting the cylinders bored and honed for new pistons. I am going the 'depression era' route of attempting to make what I have work. I have a number of cast iron J era pistons and a pile of fat J rings so I have to think that some combination of pistons and rings will give this motor enough compression to fulfill the suck, spark, blow trilogy that makes an engine run. Attached are pictures of the fixture I am using to turn a piston down to a usable diameter.
        Years ago, I had a "lay-off" job that paid the bills before I got called back to my good job. The lay-off job was at a race shop that built high quality, big horsepower racing engines from NASCAR, to Saturday night mayhem racers. The owner was Bo Law who was a NHRA champion from the '60s and whose business is still going. Brilliant motor builder, but not fun to work for. He had this piston fixture to do motor-head stuff to pistons that I didn't understand, but I admired how well it worked and how well it located and centered a piston. So, that is what I am doing to make a piston fit a cylinder bore. . . Low tech in my universe but I just want it to run.
          • 8231
          Looks a lot like my draw bar, Eric.
          If you figure out how to cam-grind pistons, I'll send you an oversized Chief blank to practice upon.
          • chuckthebeatertruck
            • Jun 2018
            • 690
            Generally, cast iron pistons are not "cam ground" in the same fashion as alloy pistons.
            Most cast iron pistons have at most .002 ovality and most cast iron pistons are fit at .001 on the skirt bottom and .0015 on the top of the skirt. This is not per inch - -this is for any bore 1 to 4 inches in diameter.
            So, if you have a motor where you have concern the pin may cause a differential expansion you can easily reduce and blend that side of the piston with a fine cut file. You simply "relieve" and blend the area about 3/4 of an inch on either side of the pin and about half the pin diameter above and below. Viola -- "cam grinding" on cast iron.
            For your turning, Eric, I almost always use tail stock pressure on piston crowns to ensure no slip. There's no need for a draw bar and the resultant internal pressure from "pulling" the casting. If you have a ten thou test indicator - you will see the piston "spring" when you release the draw bar pressure.
            Cast iron pistons are not like alloys -- and they last forever.
              • 6008
              Both cylinders have missing sections of the bottom fins. I was going to let it slide, but while they are separate, I decided to make that repair. I made a steel disk of the appropriate I.D. and O.D. which was more work that I anticipated but it was worth the effort. I finished the rear cylinder this morning. The following pictures show the progression. I would have done the front cylinder but I will be having hand surgery tomorrow and better get my hand clean, and ready. I hope the recovery is not too long as I get pretty grouchy if I don't have anything to do.
                • 6008
                A few more pics.
                • Peter Cooke
                  • Aug 2012
                  • 568
                  That looks really good Eric. Well worth the effort! Good luck with the hand surgery.
                  • Tommo
                    • Sep 2001
                    • 1320
                    Eric
                    If you are looking for piston rings I have a quantity of .030, 040, 050 and 080 thou oversize NOS rings
                    They are boxed as per piston sets in original packaging.
                    $30 USD per set.
                    Tommo
                    Peter Thomson, a.k.a. Tommo
                    A.M.C.A. # 2777
                      • 6008
                      Thank you for making those rings available to me, Peter. I'll have to get back in my shop and re-evaluate my piston and bore dimensions, but new rings would deliver good compression. At this time I'm out of commission with hand issues. I had the carpal tunnel surgery which went well, but there are definite limits to what I can do until it heals.
                      Hand before surgery:
                      Hand today:
                        • 6008
                        I am now at 6,000 POSTS ! Does the AMCA have some kind of windbag award for bloviating that much? If there is, I would probably have to go to the back of a long line to get my award
                        My hand is doing well, but I am trying to minimize the stress I subject it to. I love working on things and expect my hands to do what my brain demands of my hands, but that is what always gets us humans in trouble. Regardless, I can't sit still so I have continued on the cylinder repairs but taking it slow and easy.
                        I've been slowly working on the cylinder fin repairs but found that the top of the Harley F/J cylinders present some difficult geometric challenges. The fins are in a radius around the center point of the cylinder bore and are in a 14 degree pie shape separation from fin to fin. Horizontal, parallel fins around a bore are no problem to get right, but that sunburst array on the top is a different problem altogether. I tried a number quick easy tricks to get the doner fin in place for brazing but a halfass set-up just won't work. I finally came up with the following fixture; phew! didn't think I was going to be that invested in what I thought would be a simple project.
                        • painterdale
                          • Oct 2013
                          • 423
                          #27
                          Eric! Good to hear your rehab is progressing. I always enjoy seeing how you overcome the obstacles in the work that you do. I find your contributions interesting and informative. Although I'm pretty sure I haven't read all 6000, I never skip over them. You always seem to have something cool going on.
                          Here's to the next 6000!
                          Dale
                            • 2030
                            #28
                            Looks great Eric. Some times you have to be creative.
                            • jim d
                              • Sep 2010
                              • 280
                              #29
                              Congratulations on the 6000 posts. I certainly understand your desire to get a job done right. Even when making the tool or fixtures to do a task requires as much or more time than completing it.
                              Jim D
                                • 6008
                                #30
                                The fixture worked well and I got the replaced fins brazed in. I wish I was better at brazing but it's a solid repair, and it is what it is. I've always been in awe of good welders and think it is as much an art as it is a skill; a skill set I just don't have. Same with woodworking; I can weld, or nail 2 things together but it ain't going to be pretty.
