Motor work on a 1916 H-D
    • 6033
    I have learned that when I take a motorcycle apart, it is wise to stay on course; provided I don't walk everything off a cliff. Most motorcycles come apart easily, so it doesn't take long to have a motor-less frame. My goal is to have a decent running motor which it has not been. It did run, but very hard to start, and ran poorly when it did. It has a rebuilt (hot) magneto, and a L&L carb in place of the mysterious Schebler. I am far from being any kind of engine mechanic, and in spite of Harley-Davidson's excellent J era motor assembly guides, I never got it to run well. So, I have a theory that it has low compression, even though it needed a healthy kick to get anything out of it. Even with low compression, I would think it would at least stay running but low on power. I'll get into that when this project is further along, so, this is where I am at right now.
    • 6033
    By the way, I did hug my Harley today and I can tell you that motor is a lot heavier than it looks, and I am weaker than I thought . . . Did hork it onto the bench though.
    • PaulCDF
      • Aug 2019
      • 1431
      Nice Eric; always and inspiration you have me looking at my 741 parts pile Indian and trying to inventory and give myself some illusion of organization. Like that engine stand.
        • 6033
        I've made steel engine stands that become useless hunks of garbage that you have too much work into and can't bring yourself to throw away. I won't shed a tear when this wooden stand has served it's purpose.
        • PaulCDF
          • Aug 2019
          • 1431
          I hear you; I get running around "in the weeds" around a project trying to create "the perfect setup" when I should just sit my A** down and get to work.
            • 6033
            Will a 1917 and later J series cam work in a1916 motor? I have the later 4 lobe cam in my '16 motor with the later cam followers. I have been told that a '17 and later cam and followers will work in the earlier twin motors but I'm trying to make sure I cover the bases, and why this motor isn't running well. I did find the piston rings were quite stuck with thick oily goo so I wonder if that was a problem. As I have said many times, I am not a motor guy so any advice would be appreciated.
              • 6033
              I'll keep posting until someone tells me I'm screwing everything up. I washed the aluminum cases, and covers in ALL detergent and lightly scrubbed with a low aggessive 'Scotch-Brite' pad. The steel parts will be cleaned with diesel fuel.
              • knucklehead 61
                • Sep 2016
                • 350
                yes, the 17-29 type 4 lobe cam is a drop in for 15-16 (& possibly 11-14 twins as well) & is a performance upgrade.
                J motors like a lot of advance. too little will make them hard to start.
                • chuckthebeatertruck
                  • Jun 2018
                  • 695
                  They are heavy. Heck, even prewar singles are heavy.
                  Be nice to those pistons. I wrap rags around conrods to avoid any risk of knocking a skirt.
                  I adore making up simple wooden boxes for stands. I’ve tried the steel stands and sold them on. I like just putting together a simple h or a box.
                  While a lot of guys scoff at 5:1 or 4:1 bikes, when you have cylinder volumes of 500cc or more, you’re getting a lot of stuff moving. I find I often need to boot “low” compression bikes more than I’d think.
                  I once had a flatty with hairy cams that barely developed 80psi on a compression gauge. It had fantastic leak down numbers, though. It was a stout bike to start. It also ran very sweetly and pulled quite well. I never disassembled it. I simply tuned it and enjoyed.
                    • Jun 2018
                    • 695
                    I like your photos, Eric. They have a very nice quality that suits the motor well.
                    • JoJo357
                      • Feb 2016
                      • 3301
                      I'm enjoying the progress and quality pictures Eric~Keep it going & Great Luck.
                      *M.A.D.*
                      • PaulCDF
                        • Aug 2019
                        • 1431
                        Looks Great Eric keep posting
                        • montuckymatt
                          • Jan 2019
                          • 46
                          Love these pictures. Sometimes just looking at the things around the bike are almost as good as the bike. Garage walls and workbench’s tell stories too. Lovely all around.
                          Nothing left to do but smile, smile, smile....
                          -good ol GD
                            • 6033
                            I agree with you Matt. . . Back on topic, I have been measuring the cylinders, and pistons and have not come to a solution for moving forward. I think I can get the original junk to work as I did find problems during disassembly, and inspection; but, the right way to do this is new pistons, and boring & honing the cylinders. The problem with that is finding someone that can do blind bore cylinders properly. I know that modern outboard marine engines are blind bore and my wife's nephew is a highly skilled, and experienced boat mechanic, but he doesn't do that anymore and sold that business. I'm still noodling scenarios in my head, so that is where we are at today.
                            • BigLakeBob
                              • 2767
                              What is the total depth of the bore in the cylinder?
                              Bob Rice #6738
