Guys Im rebuilding a 25 JD. I'm installing the oil breather gear beside the pinion gear and trying to find info about cloking the gear. It has a mark on the gear. The pics I took before disassembly looks like the mark is clocked to the 1 o-clock position. Please confirm before I close the cover..... Thanks in advance.
1925 JD Breather Gear Clocking in Cam Chest
Once all the cam timing is done and all the dots lined up you will find an inverted U / V shape stamped at about 1 o'clock on the boss that surrounds the crankcase breather.
The dot on the breather is centralised in this U / V.
Don't rotate the engine at all prior to fitting the breather valve in this position.Peter Thomson, a.k.a. Tommo
A.M.C.A. # 2777
- 2 likes
