1925 JD Breather Gear Clocking in Cam Chest
  • Bbowers882001
    • Aug 2016
    • 4
    Guys Im rebuilding a 25 JD. I'm installing the oil breather gear beside the pinion gear and trying to find info about cloking the gear. It has a mark on the gear. The pics I took before disassembly looks like the mark is clocked to the 1 o-clock position. Please confirm before I close the cover..... Thanks in advance.
  • Tommo
    • Sep 2001
    • 1319
    Once all the cam timing is done and all the dots lined up you will find an inverted U / V shape stamped at about 1 o'clock on the boss that surrounds the crankcase breather.
    The dot on the breather is centralised in this U / V.
    Don't rotate the engine at all prior to fitting the breather valve in this position.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    • Bbowers882001
      • Aug 2016
      • 4
      Thanks! That’s what I thought.
