Tires
  • wyatt emp
    • Nov 2010
    • 163
    Surface rust only. Very solid.
      That rim is totaled. Surface rust my ass. You run a tire on that, why not put a gun to your head! Bob L
      • Tommo
        • Sep 2001
        • 1321
        Somewhere, back a ways, I posted a very long description on how to work out tyre sizes to rim sizes for beaded edge/clincher wheels.
        Basically a 28 x 3 tyre would have a 22 inch rim
        3 plus 3 = 6
        subtract the 6 from 28 = 22 which is your rim size.
        Cory can you find that previous post on this subject as it would save an awful lot of typing
        Peter Thomson, a.k.a. Tommo
        A.M.C.A. # 2777
          • Feb 2003
          • 5353
          I recall that post Tommo. I'll see if I can drum it up.
          Cory Othen
          Membership#10953
            • Feb 2003
            • 5353
            Here ya go!! The details are in post #7
            http://www.antiquemotorcycle.org/bbo...her+tire+sizes
            Cory Othen
            Membership#10953
            • Tommo
              • Sep 2001
              • 1321
              Cory
              I owe you another beer now that saved me a hell of a lot of one finger typing.
              A.M.C.A. # 2777
                • Feb 2003
                • 5353
                Tommo!!! It's the least I can do. Your input on this forum has proven to be invaluable.
                Cory Othen
                Membership#10953
                • wyatt emp
                  • Nov 2010
                  • 163
                  Rust
                  Click, Click!!!
                  • Sargehere
                    Member since 1972
                    • Jul 2006
                    • 971
                    These are examples of what your '28 JD might look like when you finish, Wyatt:
                    This is a '29 JD on white 3.85x27 clincher tires (& 20-inch clincher rims):
                    This is Bob Royle's 27 JD that he converted to modern, drop-center 4.00x18 Dunlop K-70 tires, due to the complete unavailability of authentic clincher tires, during the 1970s:
                    This bike is now in Nick Muth's museum
                    ( www.nickscustomcycles.com/ ) in Williamstown, NJ
                    Spokes to do a conversion like that are probably still available from Buchanan's, b.t.w.
                    This is a heavily airbrushed 1929 JDH "Two-Cam" on OEM 3.85x27 clincher tires:
                    Good luck to ya, Wyatt, and God bless!
                    Gerry Lyons #607
                    http://www.37ul.com/
                    • Tommo
                      • Sep 2001
                      • 1321
                      Wyatt
                      The major thing you must take into consideration is that air pressure and air pressure alone keeps the tyre on the rim.
                      If the rim has a rust pitted edge or an edge that has got sharp due to media blasting, grinding or what-ever has been used to clean up the rim, the edge of the rim will over a period of riding cut the bead off the tyre.
                      The result of this generally hurts both the body and the pocket
                      It is very important that the rim edge is smooth and rounded so that it doesn't chafe and cut the bead.
                      I saw evidence at the Barber festival where someone who shall remain nameless had cut both bead flaps off the tyre to make it easier to fit.
                      This is also a no-no as the flaps stop the tyre from turning inside out and coming off the bead. When the tube is inflated as well as rounding out the tyre it presses down on the bead flaps which in turn push and help to lock the tyre on the rim thus preventing the bead from rolling out of it's seat in the curved edge of the rim.
                      The gentleman who lost the tyre while at speed on the track was very lucky and damaged nothing more than his pride.
                      If you are going to do quite a bit of riding I'm inclined to agree with Bob that from that picture you posted the rim looks very rough along the edge.
                      Your call.
                      A.M.C.A. # 2777
                        • Feb 2003
                        • 5353
                        I would seriously consider Bob and Tommo's advice if you plan on riding your JD Wyatt. Check out this thread for more info regarding clinchers.
                        http://www.antiquemotorcycle.org/bbo...ight=clinchers
                        Cory Othen
                        Membership#10953
