Wheels?
  • wyatt emp
    • Nov 2010
    • 163
    Wheels?
    What are these wheels? Looks like a rare front with brake? Raer is a Corbin hub but no brake drum so racer or does the drum mount somehow? SS850542.jpgSS850543.jpg
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    Front not rare. Looks like H-D 125 "Hummer," 1940s-50s to me, but it might be some Brit or European little titter bike, too.
    Rear is a clincher rim, so before 1930 or so. See the splines on one side? Brake drum slid on them, sprocket around brake drum. Not sure of the exact model. Harley's used that system until 1936 on the VL.
    Gerry Lyons #607
    http://www.37ul.com/
    • wyatt emp
      • Nov 2010
      • 163
      SO they won't work on a JD? THey came with it...
      • wyatt emp
        • Nov 2010
        • 163
        The "splines" are actualy a nut.
          The second picture is JD rear hub 1923 up. It takes roller bearings not ball bearings. Hope this helps. Bob L
          • wyatt emp
            • Nov 2010
            • 163
            I see where the sporket mounts but where does the brake drum mount?
              On the other side of the hub. See picture. Bob L
              • wyatt emp
                • Nov 2010
                • 163
                Outstanding. ANy idea where I can get the parts? The front wheel seems to be from a Hummer. WIll it work on my JD?
                  No! The JD front brake didn't start until 28 and it's an entirely different animal. I don't know anybody that is reproducing the rear brake drum at this point. I will have them on the market by the end of the year. I'm trying to build a better mouse trap. Do yourself a favor and get on line and buy HD book #99404-93 and you will be a happier camper! Bob L
                    • 4785
                    That is not an H-D front wheel. It appears to be for a lightweight British bike. Note that it is only 36 spoke!
                    Robbie
                      • 5953
                      The best advice I can give you is the following. Get the parts book for the year machine you are working on. Know exactly what you are buying before you buy it. Do it right so you won't have to do it over. ;-)
