VL Gas Valve Sealing
  • VL Gas Valve Sealing
    Hi folks, just wondering what's the preferred special sauce for sealing the gas valve threads when installing into the tanks? I thought I'd read somewhere that Red Kote works really well, and that makes sense given the product that it is, but I can't find where I read that. As always, any and all info appreciated.
    https://www.youtube.com/watch?v=HQ3SBn6NyNg
      Peter,
      I have used this for decades now with nothing but long lasting success.
      Easily purchased at any auto parts store or online.
      Hope this helps,
      Duke Kleman
        I use EZ Turn too. Expensive, but one tube is a lifetime supply.
        AMCA #41287
        1971 Sprint SS350 project
        1972 FX Boattail Night Train
        1972 Sportster project
        1973 HD Golf Cart project
        1989 Springer Softail project
        2012 103" Road King
        2020 Heritage Classic 114
          You mean you use EZ Turn to seal the threads? Interesting...
          Jim
          AMCA #6520
            Like the commercial says, I put that s*** on everything! (gas related)
            AMCA #41287
            2012 103" Road King
              I use EZ Turn in Indian Brass petcocks. Works great. And yes, a tube lasts a lifetime.
                Thanks everyone. I should've worded my post better. Not that it should make any difference as they still thread into the tank fitting, but I was referring to the petcock style of valve. I've lapped them before nickel plating and confirmed no leaks using a bit of EZ turn on the cones. Now just need to seal the threads as I screw them into the tank fitting.
                I've got both EZ Turn and the Loctite 565 on hand so decisions decisions...
