VL Gas Valve Sealing
  • Peter Cooke
    • Aug 2012
    • 569
    Hi folks, just wondering what's the preferred special sauce for sealing the gas valve threads when installing into the tanks? I thought I'd read somewhere that Red Kote works really well, and that makes sense given the product that it is, but I can't find where I read that. As always, any and all info appreciated.
  • DEEBS47Chief1991
    Living The Dream
    • Jan 2023
    • 1256
    • dukekleman
      • Jul 2022
      • 595
      Peter,
      I have used this for decades now with nothing but long lasting success.
      Easily purchased at any auto parts store or online.
      Hope this helps,
      Duke Kleman
      • joe fxs fxr
        • Dec 2020
        • 697
        I use EZ Turn too. Expensive, but one tube is a lifetime supply.
        AMCA #41287
        1971 Sprint SS350 project
        1972 FX Boattail Night Train
        1972 Sportster project
        1973 HD Golf Cart project
        1989 Springer Softail project
        2020 Heritage Classic 114
        • Jim
          • Sep 2001
          • 786
          You mean you use EZ Turn to seal the threads? Interesting...
          Jim
          AMCA #6520
          • joe fxs fxr
            • Dec 2020
            • 697
            Like the commercial says, I put that s*** on everything! (gas related)
            AMCA #41287
            • DEEBS47Chief1991
              Living The Dream
              • Jan 2023
              • 1256
              I use EZ Turn in Indian Brass petcocks. Works great. And yes, a tube lasts a lifetime.
              • Peter Cooke
                • Aug 2012
                • 569
                Thanks everyone. I should've worded my post better. Not that it should make any difference as they still thread into the tank fitting, but I was referring to the petcock style of valve. I've lapped them before nickel plating and confirmed no leaks using a bit of EZ turn on the cones. Now just need to seal the threads as I screw them into the tank fitting.
                I've got both EZ Turn and the Loctite 565 on hand so decisions decisions...
                  Dear Peter, I use plumber's PTFE tape when screwing the fuel valves into the tank.
                  • DEEBS47Chief1991
                    Living The Dream
                    • Jan 2023
                    • 1256
                    Good stuff.
                    • joe fxs fxr
                      • Dec 2020
                      • 697
                      Tape is good, but pipe dope won't break off inside.
                      AMCA #41287
                      • DEEBS47Chief1991
                        Living The Dream
                        • Jan 2023
                        • 1256
                        Copy that.
                        • Buster
                          • 384
                          Gasoila is good with today's gas. I use EZ Turn for many nongas applications. I have attempted to use EZ Turn in areas with gas contact including sealing petcocks, after a couple of weeks the gas would eat thru it and the start weeping again.
                          • Peter Cooke
                            • Aug 2012
                            • 569
                            Thanks Steve. I hadn't thought of that. Makes sense it'd work given it's pretty much the same as the Loctite 565, just not 'liquid' as such.
                            Got the tanks back from pinstriping and have the Loctite on hand so I'll head down that path I think.
                              Dear Peter, nice paint job. Looks like you have the straight fuel outlets both sides, so don't forget that 135 degree brass adapter on the right hand side.
