45 flywheels with a ridge at the end of the taper?
    • 8247
    Originally posted by Buster View Post
    Just found verification in Palmers second addition. Page 344. 1937-73 45 motors. Pinion/Sprocket shafts 85-125 lbs. Crankpin 60-100 lbs. I just did mine last week with all around 85-90 lbs.
    Its so easy to confuse me, Buster,...
    Although its been a quarter century, I sure thought the mains were smaller than the crankpin on a 45".
    (After all, its the one that does all the work!)
    • joe fxs fxr
      • Dec 2020
      • 706
      I'm no expert, but my engineering background thinks the sprocket (and to a lesser extent, pinion) shaft taper has to resist twisting and spinning in the flywheel where the crank pin is only side loaded, and just has to resist misalignment of the wheels.
      AMCA #41287
      1971 Sprint SS350 project
      1972 FX Boattail Night Train
      1972 Sportster project
      1973 HD Golf Cart project
      1989 Springer Softail project
      2020 Heritage Classic 114
        • 8247
        If you want to break loose a taper, Joe,...
        You shock it.
        There's more from pounding pistons than from chain snatch.
        (But come to think of it, I've never found a loose taper in any motor, ever. Just skewed a bit.
        The loose tapers were all in the drivetrain!)
