1937 UL oil pump
  • ldfly112
    • Sep 2017
    • 146
    1937 UL oil pump
    Has anyone have any opinion about a aftermarket oil pump for a 1937 UL. trying to decide which to use aftermarket upgraded or stock
  • chuckthebeatertruck
    • Jun 2018
    • 697
    For a stock motor driven as normal a stock pump will be fine.
    A "four vane" rotor does move more oil, but won't impress ohv riders much.
    The aftermarket gerator style pumps move a ton of oil and do make a difference, but you must upgrade the return and think through valve covers.
    i do run a four vane on my '46, but it's also 90"
    • kitabel
      • Sep 2018
      • 471
      upgrade the return
      How?
      The Linkert Book
        • Jun 2018
        • 697
        Originally posted by kitabel View Post
        upgrade the return
        How?
        Real simple -- you buy the scavenge kit that is sold separate from the oil pump kit:
        The CHP feed and scavenge pumps are meant to work as a set.
        They are just very pricey at $600 for the feed and $400 for the return.
        • ldfly112
          • Sep 2017
          • 146
          Thanks for the advise the website is located in Sweeden anyone know of a vender in the united states that will sell the CHP pump and scavenger pump
