1937 ULH low Cylinder Pressure
Ok guys, here we go again. I went and bought new cylinders from CycleFab, with fitted pistons and valves. I had my head surfaces checked on a friends CNC Mill, they were warped, it took .020" to get them flat. Put her together and it felt like no compression when I kicked her. I put a quality compression gauge and 22 PSI. I squirted a little Corrosion X in and 26 PSI.Double checked the valve clearances and perfect. Now, with milled heads and new cylinders with fitted pistons, my PSI should be up there a little more. Only answer would be a HUGE ring gap, or possibly the cylinder decks didn't get machined enough? She's on the lift begging to get tore down, but I may be missing the obvious????Tags: None
