1937 ULH low Cylinder Pressure
  • shinedogg
    replied
    OK so after fine tuning my home made leak down tester, I put 150 psi in each cylinder, which slowly leaked down until about 90, then held. I thought that was pretty good. I turned the engine over until compression started in the front cylinder. Tapped the kicker over until the mark came up in the timing hole, not straight up, but almost. The small cam of the timer was almost ready to start opening the points. With a little coaxing, and the ignition on, I turned the advance and the plugs fired. The pictures show before I turn the timer. Anything wrong here, before I take her down off the lift to start kicking?20200402_201801.jpg20200402_201736.jpg
    replied
    If your "leak-down" test equipment, Shinedogg,..
    Puts air to the combustion chamber at the sparkplug holes, then you might avoid the bother of calculating the rate.
    Just listen at the timing hole, carb, and exhaust as you turn it through.
  • knucklehead 61
    replied
    Originally posted by shinedogg View Post
    She hasn't run yet with these cylinders
    hard to get an accurate reading when the parts haven't been seated & broken in yet.
  • shinedogg
    replied
  • knucklehead 61
    replied
    have the rings been broken in & fully seated yet, or are you testing before firing it up?
  • shinedogg
    replied
    I just finished a garage made leak down tester with gauges, fittings and a air spray nozzle. Test tomorrow!
    replied
    Error is additive, Tom!
    The concentricity and alignment of the guide's valve bore will always be subject to production variances, but I only found guides really bad from India.
    Then add installation variances (including fitting for the valvestem), and every seat must then be cut piloted to that.
    On a veteran, one hopes there is enough meat left in the casting.
    On a new production, I would expect to cut a lot just to get to minimum stem protrusion.
  • Rollo
    replied
    Yeah got thinking about it and you do need to guide to center the cut for the seat. My bad! Corona virus got me. So if the guide acts as the mandrel to center things up how would it end up being out of round? Only thing I can think of is guide pressed in crooked? How far out is it? Would think that once you cut the seat and dropped in valves (test fitting) either it would be obvious that the valve was not seating properly or there would be binding on the valve stem? Until it is figured out I wouldn't place blame on any particular person or component. Not defending ACF here as I have had my own issue with them but also know I have had pretty good work done as have others over the years.
    Tom (Rollo) Hardy
    AMCA 12766
    replied
    Originally posted by Rollo View Post
    ... I would think that you would cut the seats first then drive in the guides but again...
    I think its the other way 'round, Tom!
    The guide is pressed-in first, so the seat can be cut concentric to however it goes in.
    (That's one reason why so many veterans are sunk so deep: Too many guides have been arbitrarily replaced.
    And an over-sized guide is rarely-if-ever going to follow the bore perfectly, because the bore aint' perfect if it needs it.)
  • Rollo
    replied
    I am not a machinist so I can't answer your question but maybe Cotton's response sheds some light on it. I know a number for folks that have those set ups from Paul and didn't seem to have those issues and are running them fine. I would think that you would cut the seats first then drive in the guides but again I am not an expert machinist so.... Good luck figuring it out.
    Tom (Rollo) Hardy
    AMCA 12766
  • shinedogg
    replied
    Thanks Tom, but wouldn't seat to guide concentricity be due to cutting the seats, which falls into CycleFabs lap, not Kibblewhite? Just a question.
    Cotten, Agreed
  • shinedogg
    replied
    I would be careful here as Paul uses Kibbelwhite valves and guides for those. May not be a problem from him but them. He has them made up specifically for him and to his specs. so would think that if there is a problem it would be with all of them. I know several folks who have his cylinders and that was never a problem for them. Might have had other small issue but not that. I have had him do several motors for me over the years and while I can't recommend him right now due to delays in getting work out I would say he has spent more time and money figuring out HD flat head than anyone I know. I am sure if you find he is at fault he will make it right. Good luck!
    Tom (Rollo) Hardy
    AMCA #12766
    replied
    Not to defend anybody, Folks,...
    But you can cut a seat 'true' to a 'concentric' guide,
    Mark it for indexing, press it out,
    Press it back in indexed,...
    And it still won't be perfectly concentric to the seat.
    PS: Place any guide in question upon a mandrel (such as NEWAY seat cutting pilots), and put it between v-blocks for inspection with a decent indicator.
  • Rollo
    replied
    Tom (Rollo) Hardy
    AMCA #12766
  • shinedogg
    replied
    So I just heard that some of Cyclefabs ULH guides aren't concentric with the seats. Really? Holy Sh*t! I heard this guy was great. Ok, leak down test this weekend! Everything else checks out. Lifter clearances, clutch fully engaged. I took my OEM cylinders off after starting her because it was .060" over and the valve seats were so deep that I had to make special 7/16" wrenches to fit down in the lifter blocks to adjust them.
