1937 ULH low Cylinder Pressure
  • shinedogg
    • Sep 2009
    • 151
    Ok guys, here we go again. I went and bought new cylinders from CycleFab, with fitted pistons and valves. I had my head surfaces checked on a friends CNC Mill, they were warped, it took .020" to get them flat. Put her together and it felt like no compression when I kicked her. I put a quality compression gauge and 22 PSI. I squirted a little Corrosion X in and 26 PSI.Double checked the valve clearances and perfect. Now, with milled heads and new cylinders with fitted pistons, my PSI should be up there a little more. Only answer would be a HUGE ring gap, or possibly the cylinder decks didn't get machined enough? She's on the lift begging to get tore down, but I may be missing the obvious????
    Steve
  • shinedogg
    • Sep 2009
    • 151
    Oh, annealed copper head gaskets.
    Steve
      • 4789
      Throttle wide open for the test?
      • shinedogg
        • Sep 2009
        • 151
        Yes, wide open
        Steve
          • 4789
          Clutch not slipping?
            • 966
            Any chance the cam timing is off?
            • HDSmitty
              • Jul 2017
              • 282
              Rings on upside down? Valves seating properly?
              • shinedogg
                • Sep 2009
                • 151
                I'm checking all of that today, Thanks
                Steve
                • shinedogg
                  • Sep 2009
                  • 151
                  So I just heard that some of Cyclefabs ULH guides aren't concentric with the seats. Really? Holy Sh*t! I heard this guy was great. Ok, leak down test this weekend! Everything else checks out. Lifter clearances, clutch fully engaged. I took my OEM cylinders off after starting her because it was .060" over and the valve seats were so deep that I had to make special 7/16" wrenches to fit down in the lifter blocks to adjust them.
                  Steve
                  • Rollo
                    • Nov 2008
                    • 599
                    I would be careful here as Paul uses Kibbelwhite valves and guides for those. May not be a problem from him but them. He has them made up specifically for him and to his specs. so would think that if there is a problem it would be with all of them. I know several folks who have his cylinders and that was never a problem for them. Might have had other small issue but not that. I have had him do several motors for me over the years and while I can't recommend him right now due to delays in getting work out I would say he has spent more time and money figuring out HD flat head than anyone I know. I am sure if you find he is at fault he will make it right. Good luck!
                    Tom (Rollo) Hardy
                    AMCA #12766
                      • 8243
                      Not to defend anybody, Folks,...
                      But you can cut a seat 'true' to a 'concentric' guide,
                      Mark it for indexing, press it out,
                      Press it back in indexed,...
                      And it still won't be perfectly concentric to the seat.
                      PS: Place any guide in question upon a mandrel (such as NEWAY seat cutting pilots), and put it between v-blocks for inspection with a decent indicator.
                      • shinedogg
                        • Sep 2009
                        • 151
                        Tom (Rollo) Hardy
                        AMCA #12766
                        Thanks Tom, but wouldn't seat to guide concentricity be due to cutting the seats, which falls into CycleFabs lap, not Kibblewhite? Just a question.
                        Steve
                        • shinedogg
                          • Sep 2009
                          • 151
                          Cotten, Agreed
                          Steve
                          • Rollo
                            • Nov 2008
                            • 599
                            I am not a machinist so I can't answer your question but maybe Cotton's response sheds some light on it. I know a number for folks that have those set ups from Paul and didn't seem to have those issues and are running them fine. I would think that you would cut the seats first then drive in the guides but again I am not an expert machinist so.... Good luck figuring it out.
                            Tom (Rollo) Hardy
                            AMCA 12766
                              • 8243
                              ... I would think that you would cut the seats first then drive in the guides but again...
                              I think its the other way 'round, Tom!
                              The guide is pressed-in first, so the seat can be cut concentric to however it goes in.
                              (That's one reason why so many veterans are sunk so deep: Too many guides have been arbitrarily replaced.
                              And an over-sized guide is rarely-if-ever going to follow the bore perfectly, because the bore aint' perfect if it needs it.)
