J B Weld or locktite
  • jug
    • Jul 2018
    • 112
    Want to replace bushings for clutch lever on servi but one side is washed out some. hole is ,504- .520 bushing o.d. is .500. Will J B Weld do the job and if so which number? I see there are a lot of them listed. How about Locktite? Many moons ago we used a lot of them but can not remember which one for steel to cast. Help has always been great coming from you guys. Hope to hear more. Thanks
  • rwm
    • Dec 2006
    • 1302
    buy a new clutch lever.
    rob ronky #10507
    www.diamondhorsevalley.com
    • jug
      • Jul 2018
      • 112
      I worded it wrong. Bushings go in the sprocket cover. The lever pivots on them. It looks likes that cover is had to find.
      • 41craig
        • Nov 2010
        • 410
        There are a few servi-car sprocket covers on Ebay right now. It just depends on what year you are working on. Also, Throttle Masters in Chicago used to have a lot of servi-car parts.
        Craig
        • Rubone
          • Aug 2004
          • 4784
          I have a complete assembly available. I would have to inspect it to see the condition of the bushings. Let me know if you are interested.
          • jug
            • Jul 2018
            • 112
            Robbie, it is a 69 with electric start. Thanks for the offer. Part no. for cover is 34871-64. 64 being the first electric start.
            • Rubone
              • Aug 2004
              • 4784
              No problem, that one may be tough.
              Sounds like weld it and rebore it.
              • RCamp
                • Jul 2012
                • 99
                Colony and Flatland have the bushings you need
                • jug
                  • Jul 2018
                  • 112
                  RCamp, I have new bushings. Just need to make the one lose hole fit better. thanks
                  • jug
                    • Jul 2018
                    • 112
                    Have not used J B Weld but I seen stories of it for other things like sealing nipples. Is it not good to use for this problem? Some of these parts are hard to find and very pricey. Help!
                      Gadfly from the Dumpster
                      • 8233
                      I am not familiar with the assembly, Jug,..
                      But usually its easiest to true up the hole, and then cut an oversized bushing to fit.
                      • jug
                        • Jul 2018
                        • 112
                        Thanks for all the ideas, Guys. Best deal yet. I have a new cover coming. Not taking any chances.
                        • jug
                          • Jul 2018
                          • 112
                          Not a reply to this thread only but for all the answers I got from you people the last couple years doing my 69 servi. Thanks to all. Happy Thanks giving
