Want to replace bushings for clutch lever on servi but one side is washed out some. hole is ,504- .520 bushing o.d. is .500. Will J B Weld do the job and if so which number? I see there are a lot of them listed. How about Locktite? Many moons ago we used a lot of them but can not remember which one for steel to cast. Help has always been great coming from you guys. Hope to hear more. Thanks
J B Weld or locktite
I have a complete assembly available. I would have to inspect it to see the condition of the bushings. Let me know if you are interested.Attached FilesRobbie Knight Amca #2736
No problem, that one may be tough.Originally posted by jug View PostRobbie, it is a 69 with electric start. Thanks for the offer. Part no. for cover is 34871-64. 64 being the first electric start.
Sounds like weld it and rebore it.Last edited by Rubone; 10-19-2019, 05:44 PM.Robbie Knight Amca #2736
I am not familiar with the assembly, Jug,..Originally posted by jug View PostRCamp, I have new bushings. Just need to make the one lose hole fit better. thanks
But usually its easiest to true up the hole, and then cut an oversized bushing to fit.
...CottenAMCA #776
