Hi, I'm building a 37 U flathead. Would anyone know the range or date when the 5th trans mount on the kick start side started?
1936 to earley 37 EL U transmission
The 1938 or 1939 parts book may tell you.Be sure to visit;
From my experience only the very early 1937's used the transmission without the fifth boss. I see Ralph says mid production and that may be true but in looking at a lot of OEM type 1937's I have only seen 2 that had the early transmission. I have never seen any literature such as Shop Dope that supports a time frame.
Jerry
Originally posted by JDoorn View PostHi, I'm building a 37 U flathead. Would anyone know the range or date when the 5th trans mount on the kick start side started?
Originally posted by Jerry Wieland View PostFrom my experience only the very early 1937's used the transmission without the fifth boss. I see Ralph says mid production and that may be true but in looking at a lot of OEM type 1937's I have only seen 2 that had the early transmission. I have never seen any literature such as Shop Dope that supports a time frame.
Jerry
If your serial number is 5000 you most definitely need the case with the cast in 5th boss. Jerry
Originally posted by JDoorn View PostThat's what I read, (early 37) There probably wasn't any records. When they ran out they just started using the new ones. I thought about calling the HD museum to compare #s . mine is after 5000 but don't know what # they started with. Thanks!
Originally posted by Robert Luland View PostThey were cheap! I can almost lay bet that the fifth bolt frame bracket was there on the frame right up until the first tranny with one got mounted. Bob LLast edited by Chris Haynes; 03-31-2019, 01:28 PM.Be sure to visit;
That was there with the very late 36's. The late 36 and early 37 had a bracket the bolted to the kicker cover studs then to the 5th mount on the frame. They are shown in the 37 and later parts book.
So the current thinking is late 36 frames and all 37 frames have the 5th frame bracket and late 36 and early 37 use a bracket from the kicker cover to the frame bracket.Last edited by 1950Panhead; 03-31-2019, 12:48 PM.
Originally posted by 1950Panhead View PostNo doubt.
Page 36 in Palmers book has a photo of a 37 frame with a brazed 5th mount on the frame. (I think)
So the current thinking is late 36 frames and all 37 frames have the 5th frame bracket and late 36 and early 37 use a bracket from the kicker cover to the frame bracket.Be sure to visit;
Originally posted by Jerry Wieland View PostIf your serial number is 5000 you most definitely need the case with the cast in 5th boss. Jerry
To be really technical later 1937 transmission case is a one-year only item. Jerry
Originally posted by JDoorn View PostThanks Jerry; I almost bought the early case at Davenporte last year. I had to get a 37. I hope I'm still alive to finish it. That does make the trans a little easier. I know they were still vented through the kick cover though and I think the top cover was good for 36-38
Changes to '36 parts can be found in the 1937, 1938, 1939 and 1940 parts books. Later books aren't much help. They generally call out when the change took place. For example the ignition timer changed design at motor number 1222.Be sure to visit;
