1936 to earley 37 EL U transmission
  • JDoorn
    • Oct 2018
    • 15
    Hi, I'm building a 37 U flathead. Would anyone know the range or date when the 5th trans mount on the kick start side started?
    • 5955
    The 1938 or 1939 parts book may tell you.
    • RCamp
      • Jul 2012
      • 99
      Fifth mount was added mid year '37
        • 2024
        From my experience only the very early 1937's used the transmission without the fifth boss. I see Ralph says mid production and that may be true but in looking at a lot of OEM type 1937's I have only seen 2 that had the early transmission. I have never seen any literature such as Shop Dope that supports a time frame.
        Jerry
        • JDoorn
          • Oct 2018
          • 15
          Jerry
          That's what I read, (early 37) There probably wasn't any records. When they ran out they just started using the new ones. I thought about calling the HD museum to compare #s . mine is after 5000 but don't know what # they started with. Thanks!
            • 2024
            If your serial number is 5000 you most definitely need the case with the cast in 5th boss. Jerry
              They were cheap! I can almost lay bet that the fifth bolt frame bracket was there on the frame right up until the first tranny with one got mounted. Bob L
                • 5955
                That was there with the very late 36's. The late 36 and early 37 had a bracket the bolted to the kicker cover studs then to the 5th mount on the frame. They are shown in the 37 and later parts book.
                • 1950Panhead
                  • Jun 2010
                  • 343
                  No doubt.
                  Page 36 in Palmers book has a photo of a 37 frame with a brazed 5th mount on the frame. (I think)
                  So the current thinking is late 36 frames and all 37 frames have the 5th frame bracket and late 36 and early 37 use a bracket from the kicker cover to the frame bracket.
                    • 5955
                    Originally posted by 1950Panhead View Post
                    No doubt.
                    It isn't thinking. It is fact found in the parts book.
                    • JDoorn
                      • Oct 2018
                      • 15
                      Thanks Jerry; I almost bought the early case at Davenporte last year. I had to get a 37. I hope I'm still alive to finish it. That does make the trans a little easier. I know they were still vented through the kick cover though and I think the top cover was good for 36-38
                      • 1950Panhead
                        • Jun 2010
                        • 343
                        Chris,
                        There are photos of the brackets on page 61 of the 37 parts catalog.
                        2263-36 obviously bolts to the kicker cover.
                        2263-36a resembles the brazed frame bracket, however I have never seen one.
                          • 2024
                          To be really technical later 1937 transmission case is a one-year only item. Jerry
                          • JDoorn
                            • Oct 2018
                            • 15
                            I’ll have to find that parts book. I have 36-48 and a lot of the illustrations are for later years, also my Palmer book shows Page 36 has 49-57 frames. It has 1994 copy right. There must be a later addition.
                              • 5955
                              Changes to '36 parts can be found in the 1937, 1938, 1939 and 1940 parts books. Later books aren't much help. They generally call out when the change took place. For example the ignition timer changed design at motor number 1222.
