Could Use Some Help Identifying This Engine
    • Mar 2003
    • 1052
    thanks for that link rob, this will be several hours of good reading. in most of the pictures i have seen of holley engines, they look like they changed them around a little every year. if toms engine were a holley, i believe it would be 1901 or earlier. this is just a wild guess though. i appears that the holley car was chain drive, and toms engine is belt drive. its a mystery.
    www.motorcyclecannonball.com
      • Feb 2003
      • 5353
      Courtesy of Tom.....
      Cory Othen
      Membership#10953
      • Tom Wilcock
        • Jan 2008
        • 333
        could use some help indentifying this engine
        Just noticed this 1903 Marsh also has what looks like the identical carb. The engine is also similar with the long studs for the head and cylinder. The crankcase is different. Mine has mounting holes on the bottom. Tommarsh.jpg
          • Feb 2003
          • 5353
          Tom, it's hard to tell from these old ads but while the carb looks close, I'm wondering about that exhaust valve pocket? Does it look like it extends out past the cylinder a little further than your engine? This is proving to be a tough one. This is an add from 1902.
          Here's a little clearer image from 1903.
          1900 I could be wrong but the carb appears to be closer to the cylinder. The pulley on your engine has me wondering though. Do you think anything had been apart on it prior to your disassembly?
          Cory Othen
          Membership#10953
          • Tom Wilcock
            • Jan 2008
            • 333
            Cory It has been apart before. It shows the usual chisel marks on the crankpin nuts. Tom #381
