Hard starting 1964 R69S
  • Coolbreeze
    Long Rider
    • Aug 2007
    • 320
    My 1964 R69S does not want to start -- whether hot or cold. It has gas, compression, spark, and timing. I have replaced carbs and coil more than once.
    I am convinced the spark is weak because the magneto magnets are weak. If that is so, would rare earth magnets cure the problem? Where might I acquire such magnets?
    George Tinkham
    Springfield, IL
    www.virmc.com
    AMCA # 1494
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    1984 Moto Guzzi V65Sp
  • Coolbreeze
    Long Rider
    • Aug 2007
    • 320
    Thank you for the suggestions. I may ask Morris Mag if they will sell me a set of rare earth magnets cut to the correct dimensions.
    George Tinkham
    Springfield, IL
    www.virmc.com
    AMCA # 1494
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
      • 4778
      Just find an old tractor repair shop and get your magnets recharged.
      • Somer
        • Jun 2008
        • 18
        My 1st suspicion on BMW /2's is the condenser. Get one with a pigtail from an auto supply. All condensers are the same. See if that helps.
        • Coolbreeze
          Long Rider
          • Aug 2007
          • 320
          A "BMW Powerdynamo 12 volt conversion kit" is offered on Ebay for $675. Has anybody tried this conversion? This may correct the temperamental starting R69S. I have tried all the tuning tricks, but have not re-energized the magneto magnet yet.
          George Tinkham
          Springfield, IL
          www.virmc.com
          AMCA # 1494
          1941 Indian 841
          1948 Indian Chief
          1956 H-D KHK
          1960 CH
          1964 BMW R69S
          • Lyle Manheimer
            • Mar 2008
            • 193
            Wow, a bit pricey for me. My '65 R50 became hard to start and it was determined to be the mag coil. When the bike was warm it was hard to start due to expansion of the mag coil and the resulting "open" in the coil. Finally it failed and would not start even when cold. Replaced the mag coil and all is fine. Once again a true one kicker. I never had the magnets re-energized.
            • PRG
              • Nov 2006
              • 612
              Howdy sir,
              Not all condensers are the same, they are rated in microferads and this becomes very apparent/important at either end of the coil output scale. I'd be inclined to remagnetize and if not satisfactory go from there.
              I did an early version of this latest conversion as depicted in the pics below. Admittedly this was the last one in a very small batch done by someone who primarily focused on Vincents, created this kit for his own use, then tried it on the BMW market which proved to be far tighter with their purse strings for the cost involved, and he subsequently abandoned the project. I cast no assertions on the effectiveness or lack there of but will say this. It includes a 100 watt alternator which would not keep up with a 50 watt halogen low beam in urban use. Prior to my purchase, my R69S had been ridden the entire time in locations with very low octane gas and therefore had rather low compression via cylinder base gaskets. When doing this conversion removed them reverting to the stock configuration with noticeably more compression. With this kit fitted my machine became more persnickety to start but the most annoying was plug dry fouling under high cylinder pressure, i.e., large throttle openings at low rpm under load. Was it a system ground problem, don't know, parked this machine over 5 years ago and never pursued remedy. Many of these kits now were/are modeled after mine, be sure to research before selecting one.
              This view shows the condensor, a rather funky setup in that NOS spares have no wire attached. One has to solder on their own at the risk of overheating the unit. Also visible is the advance setup, the most outboard placed item and the source of the most issues with this ignition system. They consist of eratic advance caused by inappropriate tensioned springs or worse, a points cam that is not symetrical to each cylinder resulting in one firing before/after its intended points which leads to shadowing of the timing marks on the flywheel when pointing a strobe at it. This by far was my principal motivation for fitting a BTH.
              Cheerio,
              Peter
              #6510
              • Coolbreeze
                Long Rider
                • Aug 2007
                • 320
                Thank you for your input. I have replaced my coil twice, with no improvement.
                George Tinkham
                Springfield, IL
                www.virmc.com
                AMCA # 1494
                1941 Indian 841
                1948 Indian Chief
                1956 H-D KHK
                1960 CH
                1964 BMW R69S
                • jim d
                  • Sep 2010
                  • 280
                  Have you checked out the Vintage BMW Owners Club website? There is a wealth of information on there. You can go on as a guest. Sometimes it is as simple as removing the mag. and cleaning everything to make sure of good grounding and contact areas. Over years of time resistance can build up in those areas that will affect the ignition. There was a discussion on that on the site. A 12 volt conversion will only affect the charging area, not starting which is controlled by the mag. coil, points and condenser. There is a download available by Don Rickles called Understanding and Maintaining The BMW /2 electrical System. It is 28 pages long and well worth being in your tech. library. Replacement condenser late 60s Ford NAPA # FA82.
                  Jim D
                  • PRG
                    • Nov 2006
                    • 612
                    Howdy sir,
                    View the last pic of the offering to which George is referring which is in the link below. Note there is nothing attached to the camshaft or any components of the mag remaining. Though touted as a 12 volt conversion far more significant is a hybrid adaption of CD (capacitive discharge) ignition - if similar to my BTH sourced version - which includes built in analogue auto advance. This latter feature is what he is focusing on.
                    CD ignition is known for its powerful spark at low starting cycle rpm and resistance to dry fouling at high cylinder pressures and was put on the mainstream map by Porsche in 1968 with the fitment of the American sourced Permatune to their 911 range for which the most powerful version, the 911S, had reached its ignition limit at roughly 90hp per liter. BTH's offerings absolutely transform the usability of a Vincents and Velocettes and I see no reason why this ignition, if indeed CD based, would not do the same for /2's. If nothing else it would get rid of the fiddly points, increasingly rare NOS replacement parts and sometimes wobbly points cam. I need to drag mine back out from the back of the shop and sort out what is likely a simple issue.
                    https://www.ebay.com/itm/BMW-Powerdy...tYjUbW&vxp=mtr
                    Cheerio,
                    Peter
                    #6510
                    • Coolbreeze
                      Long Rider
                      • Aug 2007
                      • 320
                      1. Joined Airheads
                      2. Found Dave Fahringer who volunteered to get my R69S to start like it should.
                      3. Dave found the magneto was time correctly as far as the points were concerned, but was not timed correctly as far as its orientation on the engine. It needed phase adjustment.
                      4. Now, it starts better than it ever has.
                      If I understand the problem correctly, the magneto was bolted on the engine block slightly crooked. I had no idea that was even possible.
                      George Tinkham
                      Springfield, IL
                      www.virmc.com
                      AMCA # 1494
                      1941 Indian 841
                      1948 Indian Chief
                      1956 H-D KHK
                      1960 CH
                      1964 BMW R69S
                      • ryan
                        • Mar 2017
                        • 610
                        Glad you got your bike running well. You have a nice collection!
                        • Coolbreeze
                          Long Rider
                          • Aug 2007
                          • 320
                          Shortly after getting the R69S back from Dave Fahringer, it reverted to being almost impossible to start. Look at my posts this month on this forum to see how it was returned to the level of reliability one expects from a /2 BMW.
                          George Tinkham
                          Springfield, IL
                          www.virmc.com
                          AMCA # 1494
                          1941 Indian 841
                          1948 Indian Chief
                          1956 H-D KHK
                          1960 CH
                          1964 BMW R69S
                          • PaulCDF
                            • Aug 2019
                            • 1414
                            Bummer!
                            Have you spoken with Dave Fahringer yet???
                            • jim d
                              • Sep 2010
                              • 280
                              Did you do what I suggested in my earlier post? In regard to taking the magneto and related ignition components apart and give them a thorough cleaning with a scotch brite like material and use an electrical compound to promote a good ground and retard corrosion. Most of the magneto systems on these bikes are over 50 years old and never had this area addressed. The parts may not look that bad but the combination of all of the components having some oxidation can result in a bad or intermittent grounding of the magneto.
                              Jim D
