Murph
I would like to add my opinion to your judging issue with the 1.5 deduction for blued pipes. I am a field judge and may be able to give some insight. Bluing of pipes is a subjective call on the judging field. "Normal" bluing associated with starting and limited running of a motor is generally overlooked, as it should be. Problems arise with certain makes and models when used as a daily rider while going through the judging system. Sportsters, Triumphs, BSAs, and a lot of other motors are subject to blue or yellow the exhaust pipes. This can happen while you are trying to dial the carb in or while twisting the grip on the highway. Even the best tuned carb may eventually discolor some chrome. Looking at your picture I would have to agree with the judges that the discoloration was excessive and should be a deduction. I also think the 1.5 point deduction was a little high and you should petition the new head judge to have this lowered. Ask to have the deduction lowered to 1/2 or 3/4 point. If this is done, leave everything as is and enjoy your trophies. Thank you for posting your pictures and allowing your fellow club members to join you on your quest for the Winners Circle.
