Can these wheels be saved?
  • edgemont
    • Mar 2018
    • 91
    Popped my old tire off and found some rust. Really don’t want new ones. Just sand and paint? Thanks
    This gallery has 1 photos.
    • 4789
    Very common, just do as you suggested and they will be fine.
    • larry
      • May 2009
      • 247
      Wire wheel then Rustoleum primer or silver bridge paint.
      • edgemont
        • Mar 2018
        • 91
        Thanks. I think they have plenty of steel left in there too
        • Highlander
          • Feb 2006
          • 97
          After getting the rust off, I use a rust converter spray on them. You can use the Rustoleum brand and Eastwood has it too. It seems to hold up better and prevent future corrosion.
            • 4789
            And for the future, never use a pressure washer or wand type carwash to clean your bike. Every spoke hole is a potential access point for water to enter the rims, and once there it starts the rusting process all over again. It also cane get past seals, and into every little gap causing things like rusted/frozen axles, ruined wheel bearings, etc.
              • 8242
              Personally, Edgemont,...
              I would ALOX-blast the rust down to 'gray metal', before encapsulating it with the goober of your choice.
              There are many.
              .....Cotten
              • 1937hd
                • Nov 2016
                • 62
                Never use dish soap to mount your tires it is corrosive. Spend the couple bucks and buy some Ru-Glyde at the auto parts store it works wonders.
                • ammorest
                  • Sep 2008
                  • 301
                  I use baby powder. And it makes your tires smell good.
                  Dave
                    • 8242
                    Dave
                    Beware baby powder isn't talc anymore, Dave,...
                    A lot of it is corn starch, which holds moisture.
                    I found a discarded cone of pool table talc in the dumpster!
                    • 41craig
                      • Nov 2010
                      • 410
                      The Great Dumpster Diver strikes again !!
                        • 8242
                        Diving will never be the glory it was before '08, Folks...
                        Note also that pool cue chalk is great for filling bastard files to prevent loading up with soft metals.
                        Not only is there a zilllion uses for broken cues, but I fashioned straightening mandrels for HX airvalves from pool balls.
                        And those who know my booth from Davenport know that old "felts" don't go to waste!
                        • JTR249
                          • Jul 2019
                          • 768
                          One recent product I have used is Evaporust. Many people like this because it is non-toxic and not harmful to the environment. Awesome if you have time to soak the part over-night. Best results on metal parts that are smaller and corroded or appear to be unsalvageable; plates, stands, bearings, rails--it's good for all that and of course bolts. My vertical wheels all look like edgemont's photo when I remove the tires that usually have to be cut off the rim when you get them used from sellers. Anyway, they also make a spray form Evaporust and carry it at your local auto-parts or hard-ware store. I've never used the spray, though have had much success with the soak method and wire brush after. They really do look virtually new and all you do is apply, wait, brush and clean.
                          -JR
                          36450
                          • 41craig
                            • Nov 2010
                            • 410
                            I had a pair of '40's 16" rims stripped of chrome at St. Louis Plating a few years ago. Has anyone had any experience with powder coating rims black ? Does it hold up ??
                            • JTR249
                              • Jul 2019
                              • 768
                              There is an old article in IMI about that very issue. I think it is one of Mike Tomas's early writings on chief wheel tech issues. That was one of the remedies he suggested for preventing corrosion and extending the life of the vintage Indian motorcycle wheel. He also suggested replacing all spokes with modern ones as the modern steel is stronger than what they made then, in the 30s, 40s and 50s.
                              -JR
                              36450
