1937 Indian Chief restoration
  • Flathead101
    • 45
    image_46054.jpg image_46055.jpg image_46056.jpg image_46059.jpg image_46060.png I started this restoration about a year ago, it was a basic roller project missing most of the good stuff. I acquired parts for over a decade.
  • Flathead101
    • 45
    image_46061.jpg image_46062.jpg image_46063.jpg Wheel restoration certainly offers some challenges, definitely has its moments.
    • tomfiii
      • Jun 2007
      • 316
      If you plan to ride it , upgrade old small rollers to later set up.
      • Flathead101
        • 45
        You're spot on. That's been done.
        • Flathead101
          • 45
          image_46066.jpg image_46067.jpg I will have to say, a few birthdays will go by before you round up all of the components for a pre 39’ headlight.
            • 1676
            Good start! Personally, I really, really like those 30's hard-tail Chiefs, they're iconic looking IMHO so I can't wait to follow along!
            • PaulCDF
              • Aug 2019
              • 1434
              Very nice will enjoy following your progress.
              • Flathead101
                • 45
                image_46073.jpg image_46074.jpg image_46075.jpg It’s a roller. I found a NOS set of Allstate tires at Davenport years back and they are a perfect fit.
                • Flathead101
                  • 45
                  I started repairing the fins on the head until I realized there were 18 broken fins then went to the Greer catalog.
                  • Flathead101
                    • 45
                    image_46082.jpg image_46083.jpg image_46084.jpg image_46085.jpg Transmission and primary installed.
                      • 970
                      I had some very similar Arcos on my 47,that amazingly had no cracking after probably 60+years,but the rubber was hard,making for very slippery,unsafe riding.
                      Old tires may look good but try a panic stop without sliding.
                        • 970
                        If you haven't already,I would remove the case breather plug and ,while you have heads off,put a center punch mark on the flywheel to indicate your full advance setting.
                        Makes future timing much easier.
                        • Flathead101
                          • 45
                          Hi Tom, I've done that for years. Great advice though. I put a dot with a white paint marker over the center punch mark to make it more visible.
                            God bless all of you Folks,...
                            Who can punch the side of your flywheels without knocking them slightly out of true.
                            • Flathead101
                              • 45
                              a spring loaded impact punch.
