Dads Sport Scout
  • FLFD7
    • Feb 2021
    • 739
    One of the parts missing from the bike is the horn. So I had to go thru my stash of parts for the right horn for 1941 ( and thru 1945 I think ). Fortunately I had one, and it has the right look for the bike:
    I always liked the design of this horn face, I think the art deco style goes with the skirted fender style.
    It honks, so we’re good. Going thru my box of horns I also have the horn face Indian used on their military bikes, it’s exactly the same but it doesn’t say Indian:
    Which I always thought was weird, I mean did they think the Nazis or the Japanese cared who made the motorcycle? Didn’t the jeeps have Willys stamped on the tailgate?
    One last thing, I have also found this same horn face with WARDS stamped on them:
    I have no idea what they came off of, but they show up at car shows from time to time. The horn itself is usually different then the Indian style.
    • FLFD7
      • Feb 2021
      • 739
      While I was on the chassis I figured a few things needed to be cleaned up. The rear stand before and after:
      The main frame got the same treatment. For some reason the front of the frame was painted gold, and at some point in time both the front and rear frame section were painted white, then covered up in black. This thing gonna get some nice semi gloss black and be done with it.
      Next up I tackled the fork.
      • FLFD7
        • Feb 2021
        • 739
        The forks looked ok except for all the paint missing from the right fork leg, so I took it apart and gave everything a good going over, cleaning the chromed parts and painting the rest.
        There is a ton of little parts on these forks.
        I was surprised how well the chrome cleaned up, I wasn't a fan of the chrome spring but its growing on me.
        All this fork stuff took like a week or so to wrap up, and then my friend Pete called the rear frame section all done, so that'll be next....
        • chuckthebeatertruck
          • Jun 2018
          • 697
          Thanks for sharing.
          • FLFD7
            • Feb 2021
            • 739
            Hey no problem.
            So I got the rear frame section back from welding but before painting it I wanted to give it a little test fitting. I scrounged up a set of cases and trans housing as a fixture and checked it out.
            after a little juggling and filing I was happy with it, so I don't foresee any problems during assembly. Then I gave the rear frame a quickie paint job and we're good.
            Next up I'll do the shocks.
            • FLFD7
              • Feb 2021
              • 739
              Before I get to the shocks another part missing from the bike is the headlight. So I had to dive into my stash again and luckily I had the correct Dietz light with the wires coming out of the pedestal. Also the right patina for the bike. That’ll look good I think.
              • FLFD7
                • Feb 2021
                • 739
                ok, lets get to the shocks. Gonna take them apart, make sure no broken springs, clean them up and reassemble.
                yuck, these need a good cleaning, but at least no broke springs.
                a little elbow grease, lacquer thinner, 3m pad and spray paint ready to reassemble.
                My homemade spring compressor worked fine, but those spring retainer clips are a bear to get out and put back in. It all worked out in the end.
                • FLFD7
                  • Feb 2021
                  • 739
                  Well, time to start digging into the engine.
                  Intake manifold off, like Cotten observed the original builder might have altered them, looks like he is right...
                  someone did a little creative grinding, the second picture above shows comparison with stock manifold.
                  Next up I deal with a broken off spark plug....
                    It looks just about like all the Bonnes, Joe!
                    Obviously they were hand-hogged from the standard casting.
                    (Like so many industries, the "burr bench" was probably an "entry position".)
                    The carb bore that matters is the venturi, and with today's highway speeds, "dropping in" a Bonne venturi and nozzle should help.
                    Please don't forget to grind the manifold flange flat, and lathe-cut the carb flange to match.
                    (If your lathe is a small one, you may need to conjure a counterweight.)
                    • FLFD7
                      • Feb 2021
                      • 739
                      During disassembly the spark plug in the front cylinder refused to come out. Multiple applications of PB Blaster over a couple days and a longer breaker bar resulted in the plug snapping off at the threads, immediately followed by a string of curse words. So the head comes off, many more shots of PB Blaster alternated by a little heat from a propane torch and I figured it would easy-out out...
                      Yeah, that did not go as expected....the plug body and the thread insert have apparently become one...oh well, I think Greer sells the inserts....
                      • FLFD7
                        • Feb 2021
                        • 739
                        So I continued with tearing down the engine to see what I can find
                        Somebody wasn't paying attention when they put it together in the past....
                        So I pull the front cylinder and get a big surprise....any guesses?.....
                        1941 sscout 62.jpg She's a stroker........
                        So I guess the title of this post should be my fathers Big Base Stroker Sport Scout....
                        • joe fxs fxr
                          • Dec 2020
                          • 702
                          #27
                          It probably wouldn't have helped here, but there is a spray penetrant called Kroil, or AeroKroil that works much better than PB Blaster. Its expensive, so I save it for the tough jobs. Keep up the good work.
                          AMCA #41287
                          1971 Sprint SS350 project
                          1972 FX Boattail Night Train
                          1972 Sportster project
                          1973 HD Golf Cart project
                          1989 Springer Softail project
                          2020 Heritage Classic 114
                          • HDSmitty
                            • Jul 2017
                            • 282
                            #28
                            A 50/50 mix of acetone/ATF works great as a penetrant. Hope this helps someone......Smitty
                              • Jun 2018
                              • 697
                              #29
                              some of us ADORE stroked flatheads. Yippee!!!
                              • FLFD7
                                • Feb 2021
                                • 739
                                #30
                                Well the teardown continued
                                wait a minute, what the heck.....
                                Facepalm......I have found a lot of weird hardware on this bike, square nuts, socket head cap screws, flat head socket head screws, somebody must have dipped into a coffee can full of nuts and bolts when they put it together. Well, it'll get the proper hardware when I assemble it.
