Flywheel truing
    • 8223
    #31
    By any chance, Tom,..
    Do you still have any of the original pistons and such to determine the original factor?
    No matter what the model, when possible, the fossil record should rule.
    • Tom Lovejoy
      • Aug 2006
      • 951
      #32
      yes by chance, I still have the whole assembly, except for maybe the piston rings - can't remember right now off the top of my head :-) The engine is apart, but I just pulled the shafts and flywheels, rods and all out and set them aside, but their still together. I will have to read up on how to get the info, but I will try and then get back to you guys with the info. 1 piston has a hole in it and the other is at the piston making shop, having new ones made. When I get it back I will try to figure it out and let you know what it is. I think it is stock - guessing, my bores were stock and the whole engine looked pretty good inside.
        • 8223
        #33
        For a guesstimate, Tom,..
        Please weigh your intact piston, pin, and perhaps your new rings if similar design.
        And then weigh your rod tops:
        The original reciprocating weight can then be calculated as two complete piston assemblies plus the rod tops.
        While on "knife-edges", weights can be applied at the wristpins until it achieves 'balance'.
        The applied weight plus rod tops divided by the original reciprocating weight will give the original factor.
        My memory fails, but I think the difficult aspect with a Sport Scout is that the pinion main is smaller than the sprocket main, so the knife-edges must be different heights.
        .....Cotten
        • Tom Lovejoy
          • Aug 2006
          • 951
          #34
          I did some looking today, I thought I had everything needed. I forgot, what I don't have is the wrist pins or the original rings. I will try to find some, I am getting new wrist pins, I would think they would be close to the same weight as originals ?
            • 8223
            #35
            It appears, Tom,...
            We might squeeze out a guess, but the true factor shall remain a mystery.
            (...If there ever really was one!)
