Linkert M741-1 rebuild
...Greer's will send me a venturi for an M441 ('41-'42 Indian Four), it's .816 i.d. and Todd says it will fit... so that's good, thanks again!
...whoops, I forgot to mention it's listed as out of stock. I'll see what Todd has to say.Originally posted by T. Cotten View PostGreer's lists the 100257, which is "equivalent".
As I posted, Harry!
I hope they both are Greer's own productions, as that's usually decent.
(Some Greer's offerings are from subcontractors; Trust me, I'm certain.)
PS: The 841L&R should be the same as the M17L&R venturies, depending entirely upon the quality of manufacturer, of course.
(On the whole, what crossed my benches from the predominant ebay hero sucked, in one way or another.)Last edited by T. Cotten; 04-14-2020, 02:57 PM.
Cotten, seeing as how I'm not hefty, but I'm not planning to race, either, yet there's lots of hills here.... I guess I might be happier with 13/16. But Greer's doesn't show it... in fact the only 13/16" venturi for a 1" carburetor that I can find with a quick search is one that goes to the XA Harley... and it has two different part numbers, for L and R. Will a Schebler venturi go in an M741 if I can find one? Thanks for the heads up, with a 37c.i. version I already have an unnecessary inferiority complex!Originally posted by T. Cotten View PostI'm certain Greer's would let you exchange it easily.
I 'spose it depends upon your riding habits, Harry!Originally posted by pisten-bully View PostCotten, I ordered a 3/4" from Greer's... will I notice any difference?
(If you are a very hefty boy, go small; If you want to merge with highway traffic, go bigger.)
There is some confusion as to the original DLX63 spec, since the extinct Indianmotorbikes.com spec'd 3/4" for the 45", and 13/16" for the 37".
That's a signifcant difference for small bores, and 'counter-intuitive', too!
I have encountered one M741-1 with the tiny venturi; Most had 13/16", as I believe your original Schebler had..
...CottenLast edited by T. Cotten; 04-14-2020, 02:06 PM.
Any luck, Harry,...
Finding a 13/16" venturi?
http://www.jerrygreersengineering.com/catalog.php lists only a 3/4" under their M741 listing, but there is 100257 listed for Scheblers, and would function the same as the M741-1 venturi (assuming it fits your particular body.) The only difference is the shape of the air correction chamber, which matters little if any at all.
(Caveat: I order often from Todd, but never yet a venturi.)
...CottenLast edited by T. Cotten; 04-14-2020, 01:36 PM.
It may well be the machine's original bowl, Harry!
The shapes are so similar that it would be of little advantage over a Linkert bowl.
(And the distance from manifold flange to bowlstem axis is pretty identical for DLX63 and M741-1, too.)
For your replacement parts, I would suggest an Indian-only supplier. Seriously.
Although your borewear looks only "typical", without honing and then fitting an oversize disc and venturi (not readily available), there will always be daylight.
Graciously, the disc never operates closed anyway.
PS: Please note the difference between these Schebler bowls: The bowl cap is level with the top of the bowl for many 1ΒΌ" HX and Type A DLXs, on the right.
(DLX63 on the left; sorry I forgot the photo credit..)
PPS: If your bowl is boiling, you've got other problems!Attached FilesLast edited by T. Cotten; 04-12-2020, 04:11 PM.
I also understand that with a Linkert on a 101 Scout there is an issue with the bowl being too close to the cylinders and potentially causing the gas to boil. It may be the reason someone in the past put this Schebler bowl on this Linkert? This being a 37 c.i. I’m not certain this will be a problem, we shall see! George Yarocki made some spacers in the past, so if the Linkert bowl is too close I can either use a spacer or see if I can use this Schebler bowl.
Soaked overnight in Chem-Dip and it looks better, outside:
and inside:
I should mention I had no problem getting the venturi out... there wasn't one in there!
Now to make a list and order parts, gonna need bowl, float, needles, nozzle, venturi, throttle and choke plates, throttle and choke shafts, throttle shaft bushings, and some odds and ends like new galley plugs and tiny springs for the detent balls for the knobs. Good thing labor is cheap!
Similar M841s had fixed jets, Kitabel!
And "closed" HS needles like an M88, M17s, and other military models, but not the M741 and M741-1.
(My factory blue-print specs five gallery plugs, but then it declares an impossible 7/16" float setting!)
That plug is for a drilled gallery to connect the LS needle "well" to the rest of the idle circuit.
PS: Even an auxillary jet shouldn't be higher in the bowl than the HS needle seat.
PPS: A curious note: The earliest use of an auxillary fixed jet (upon a production American motorcycle) seems to be upon some Schebler 1940 DLX130s.
(I have encountered a few, and as many without.)
Anybody know of any others?Attached FilesLast edited by T. Cotten; 04-12-2020, 01:34 PM.
I'm confused, Kitabel!Originally posted by kitabelThe original M-741 main jet would be sized for a 30.50" engine, and too small for safety with your 37". The power needle would be out of range.
Just a guess: .048", pretty close to an original H-D #0 or #11 (both 1.25mm or .0492").
Can't find one? The very common H-D #1 used in the M-88 is .052". I've soldered jet holes shut and re-drilled; try to maintain the original tapered entry to the hole.
How to identify a Linkert SV bowl: it has a threaded brass hex cap covering the needle & seat opening.
The M741 series had no fixed jet, and the main nozzle was the same #102618 as others.
(Sorry that's an Indian number, but I don't have the MOCO's equivalent handy, yet...)
Good thing they are so forgiving, huh.
...CottenLast edited by T. Cotten; 04-11-2020, 04:58 PM.
I kinda miss them! Thanks for following along Cotten!Originally posted by T. Cotten View PostRemember "dime stores"?
Oh ...this 101 is a 37 c.i. version.
