Clevis pin tool
    • 6017
    Clevis pin tool
    I made this simple fixture to drill homemade clevis pins for the cotter pin. I use 1/4" rivets, and turn the head down on the lathe. I always keep an extra clevis pin, and cotter pin in the bike toolbox.
    In the last picture, (left) raw rivet, (middle) OEM H-D clevis pin, (right) finished clevis pin.
  • dommi7
    • Jul 2001
    • 109
    Thanks for posting. Looks like a nice setup.
    I’ve sheared clevis pins before and I’d think the rivet would be too ‘soft’ to use for a brake clevis pin. Have you had any trouble with them?
    Ralph
      • 6017
      That's a good point, dommi7. I have about 10 old clevis pins and found 3 that were heat treated. I can see where hardened is good, and also where tough is good so would be curious what other think. Easy enough to heat treat small parts like that. I'm building my old trusty '51 right now and going through all the assemblies that rattle, and feel sloppy.
      • BNSONS
        • Mar 2007
        • 178
        Nice jig. But 3 nos Factory parkerized clevis pins cost 10 bucks. What's the value of your time?
          • 1672
          ...another good question! BUT: 1) satisfaction of doing it, and 2) who needs a pound of rivets, may as well put them to use! = Priceless
            • 6017
            Actually, I made this fixture for Henderson, and Excelsior clevis pins. That box of rivets cost about $10. I have 2 Hendersons and each bike needs 8 clevis pins, and Excelsors use just a few less. I've also made a good number of pins, and clevis' for other brand X owners. . . There are other motorcycles out there in the world
            • BNSONS
              • Mar 2007
              • 178
              What do you suggest on how to remove broken cotter pins out of clevises? I seem to have a collection of those.
                • 6017
                I have a collection of small drifts that I have made by grinding old taps. You can make them to suit, and they are hard enough to move something like a rusted in cotter pin without bending. Easy to break though.
                  • 8234
                  Have you tried a common chain-breaker, BNSONS?
                  • 26fhead
                    • 94
                    Eric,
                    Where are you buying your rivets?
                    Thanks Steve
                      • 6017
                      My favorite store, Steve; McMaster Carr. No minimum order, easy to deal with, fast shipping, and a huge catalog of industrial stuff. A bit pricey, but not that bad, and quality has always been excellent.
                      • BNSONS
                        • Mar 2007
                        • 178
                        Eric and Cotton, those are both good ideas that I will try.
                        • 26fhead
                          • 94
                          Eric,
                          Thanks that is where I shop quite often!
                          • otis71
                            • Jul 2015
                            • 597
                            Big Flats Rivets in NY sells rivets of all styles for about 10 cents apiece depending on size. No minimum but shipping is about $9 for the small flat rate box he uses.
                              • 5950
                              Sure. But only one of the original American companies is still in business. :-)
