Need referrals for 24 Scout tank pinhole repairs
  • Daron
    • Mar 2015
    • 13
    I have a 24 Scout with old paint with pinholes in bottom. I've cleaned it inside with Evaporust and a hand full of bolts and have knocked the rust loose that was keeping it from leaking. Surely there is someone out there who provides as a service soldering up the holes or cutting and patching the weak bottom while maintaining most of the patina to the tank. HELP!!!
    This gallery has 2 photos.
    • 1675
    Daron, I think that Indian head tank decal is much later so saving the paint (and decal) could be optional. Would open up a few more options for you,
    • Daron
      • Mar 2015
      • 13
      pisten-bully, you are correct that the decal is later but the patina is even on the bike painted in probably the 30's. Not confident I could get the similar look with a new tank distressed to look old.
      This gallery has 1 photos.
        • 6028
        I would consider a quality tank sealer. I've repaired my own tanks via solder, and new panels and that requires surgically clean metal to work with; ergo, all paint is removed. You really don't have anything to loose by using a tank sealer and if the repair doesn't work, you can always remove the sealer with paint remover, and MEK. Just make sure the sealer has clean metal to stick too.
        Love your Scout and I can see why you want to preserve it.
        • kitabel
          • Sep 2018
          • 471
          Pin hole rust: almost completely rusted through
          The Linkert Book
            • 8239
            Beware Daron,..
            Sealers are primarily to prevent future corrosion.
            Please don't trust even the most fuel-resistant sealer readily available, 'Red-Cote', to fill every microfissure.
            Your tanks must be mechanically sound first. Any oldtimey radiator shops left in your neighborhood?
            • Daron
              • Mar 2015
              • 13
              Yet kitabel and T. Cotten the potential repair must be better than a sealer as a band aid. The bike is rebuilt and sound enough to ride so sitting on a few gallons of gasoline above a hot twin isn't something I take lightly. The goal is to replace by patching the porous bottom of the tank with new metal. A scar at the bottom edge will match the rest of the bike so I can live with that. Worst case it becomes shop art and I buy a new tank and distress it.
                • 6028
                If you knew you were going to do a mechanical repair, why ask?
                • Daron
                  • Mar 2015
                  • 13
                  Exeric , To find someone willing and capable to do it for me. Thought that was clear.
                  • Peter Cooke
                    • Aug 2012
                    • 570
                    Find a radiator shop that builds them for vintage/brass cars. Easy job for them.
                    • ihrescue
                      Super Moderator
                      • Jun 2015
                      • 1145
                      I recommend a franchise fuel tank service called Tank Renu. They started primarily for antique tractors and four wheel vehicles. I used it for a leaky tank on an old Sportster but one that wasn’t in relatively bad shape overall. It cost me $300. Yes I could have bought a repop or ever a good used for less than that but it is what it is. They can actually effectively create a ghost tank inside the damaged tank out of a fuel friendly resin. It was it even 1/4 “ thick but is tough as all get out. A friend used them on a old Willys Jeep Wagon with holes animals could and did enter the tank. It has work for him for years. It’s worth a look as an alternative. I had to drill a wider passage in the petcock bung to get it big enough for it to fit the id. The resin is tough even to drill. they are around the country I had one right near home. Just know that prep work takes off all finish
                      In May 1988 Gas Tank Renu – USA, a Michigan Co-Partnership, was officially formed for the express purpose of selling Dealerships to be licensed in the technology for the process of repairing fuel and other holding tanks. The business has grown to the point that there are now 35 Dealers in the United States and […]
                      Mike Love
                      • ihrescue
                        Super Moderator
                        • Jun 2015
                        • 1145
                        Mike Love
                        I'm sorry Daron I know you are trying to keep the original paint finish. I am certain there are some talented paint artists out there that can create a believable faux aged look while you put the original tank away as an original part for whole retention purposes. Here is an article from Hotrod.com about the subject of faux age.
                        Mike Love
                        • Daron
                          • Mar 2015
                          • 13
                          Thanks Mike, I agree with all that and it likely may be my route. A new tank is available from Germany for $1200 and my caps and pumps fit it. My paint is from probably 30’s and decal is wrong so it’s a viable option. I appreciate all the input so far. That’s why I reached out to the community.
                          • joe fxs fxr
                            • Dec 2020
                            • 700
                            You could try a local welding company, look in the yellow pages (haha) or google. Don't tell them it's a gas tank until you see them, they get nervous. Once they see it's never had gas in it, they will be fine.
                            AMCA #41287
                            1971 Sprint SS350 project
                            1972 FX Boattail Night Train
                            1972 Sportster project
                            1973 HD Golf Cart project
                            1989 Springer Softail project
                            2020 Heritage Classic 114
                            • ihrescue
                              Super Moderator
                              • Jun 2015
                              • 1145
                              I just looked at the photo of the tank and I may be wrong and maybe its already been discussed but the Indian brand image looks like a stencil.
                              Mike Love
