59 panhead with sidecar exhaust question
  • renrawmot
    • Jan 2010
    • 25
    Hi everyone, i have a 59 panhead with a documented original sidecar. My question is, is there an original front exhaust pipe available that accomodated the bar that is mounted on the bike to connect the front point of the sidecar? Mine looks like someone took a hammer to flatten the pipe so the bar would fit the sidecar. Sounds confusing but maybe someone understands what i am talking about
    MONGO
    You bet ya there is. I just happen to have one of them OEM raw, brandie new! (no chrome) for the takening. PM me. Bob L
    • BigLakeBob
      • 2768
      You can also contact Tom Faber, he has them. www.fabercycle.com. Bob AMCA#6738
      Bob Rice #6738
        I have a couple i bought from Tom. My question is why they never appear in the parts or accessory catalogs?
        • Sargehere
          Member since 1972
          • Jul 2006
          • 971
          You'll find that the special "sidecar mount" indented front exhaust pipes have only a superfluous factory indentation. You will have to "custom fit" the front downpipe to fit around the sidecar mount, anyway.
          I found that the best way is to remove the sidecar mount, fit the exhaust pipe in place, and with a steel rod or a pipe just a little larger diameter than the shaft of the sidecar mount, place it through the frame loops and work it (a little "blacksmithing") until the steel rod clears the location of the sidecar mount, leaving a crescent-shaped indentation in the right place.
          It makes for a far neater installation than just "flattening the pipe with a hammer" if you make a neat, crescent indentation where it should be, leaving about an eighth-inch or so air-gap clearance around the sidecar mount shaft. There's no need to transfer exhaust heat directly through contact with the bike. The amount the exhaust flow is "throttled" is negligible, even if it's almost half the diameter of the exhaust pipe, and won't really affect engine performance
          Gerry Lyons #607
          http://www.37ul.com/
            Being as I don't have my Funk & Wagnall handy I'm not sure about what "superfluous" means. Here is the pipe that Tom Faber sells. It looks like it has plenty of clearance.
            • aka HAWG
              • Jan 2007
              • 487
              I will first use superfluous in a sentence
              chris your attitude towards barry brown was superfluous to say the least
              "superfluous - being more than is sufficient or required , excessive "
              aka HAWG
              1914 EXCELSIOR BELT DRIVE SINGLE
              1914 excelsior belt drive single carcuss
              1940 indian chief military
              1965 sportster xlch
              1969 sportster xlch bobber
              1971 bsa A65 chopper
              1969 harley ss350 sprint
              1960 harley topper
              1963 harley topper
              H model whizzer on cheiftain bicycle
              H model whizzer on schwinn bicycle
              1949 harley model 125 bobber project
              1959 harley model 165
              1960 harley super 10
              1974 indian 70cc dirt bike
              EXCELSIOR - ALWAYS MAKES GOOD
              • Mr. Big
                • Feb 2010
                • 130
                Hawg, I think you need to drive on down to Kali and just take a swing at him and get it over with. Geeeezzzz.........
                47 WL
                51 Ls Sidecar
                03 FLHT
                http://www.gouldingsidecars.com
                • Sargehere
                  Member since 1972
                  • Jul 2006
                  • 971
                  Drive? No need to drive yourself, Hawg! Just rent a bus and charter a bus tour, long way around the continent, selling tickets and filling the seats along the way. You'll fill a bus easily, maybe a couple of them, long before you reach Kali! Sounds like a money-making enterprise 2me.
                  Gerry Lyons #607
                  • Sargehere
                    Member since 1972
                    • Jul 2006
                    • 971
                    Looks can be deceiving, BTW. My poor word choice; when I used "superfluous" I meant that the indentation on the supplied ones is "superficial." Look that one up. I haven't seen a front exhaust pipe yet that didn't need some help, some customization, to clear the front lower sidecar connection. About 50% of the diameter of the pipe seem to work about right.
                    Gerry Lyons #607
                    • MJW
                      • Mar 2007
                      • 127
                      Stupendous...
                        • 4791
                        Serendipitous...
                        • rwm
                          • Dec 2006
                          • 1302
                          supercalifragilisticexpialidocious
                          rob ronky #10507
                          www.diamondhorsevalley.com
                          • junkyarddog
                            • Feb 2010
                            • 193
                            Seems like several of you just look for something to take a bite of.
                            Do you people really want the AMCA to look like a bunch of idiots?
                            Jim
                            • aka HAWG
                              • Jan 2007
                              • 487
                              what a great idea - what about doing it in the time frame of cannonball 2012 leave new york bringing anyone who want to follow the cannonballers from start to finish, can pick up others on the route. chris was way to happy be at the final party for 2010, he will probably want to get into the final party in 2012, killing 2 birds with one stone. I will try to get barry to drive bus #2
                              aka HAWG
                              1965 sportster xlch
                              1960 harley topper
                              1963 harley topper
