6V Delco Remy Horn - need help
  • DEEBS47Chief1991
    Living The Dream
    • Jan 2023
    • 1256
    I used a sheet of paper gasket material from NAPA. The rubber that insulates the electrical posts are insulators to keep the posts from shorting out on the metal shell. I traced the outer circle and then used an Exacto razor knife to cut out the inside and bolt holes. I used the top gray gasket sheet in this assortment of gasket material.
    • DEEBS47Chief1991
      Living The Dream
      • Jan 2023
      • 1256
      BTW, I did not make the post insulators but that could be fabricated with a grommet or other plastic tube. However, be mindful of heat, petroleum, and vibration when fabricating motorcycle parts. It's a rough environment. I would try chainsaw fuel line for an example.
      • Peter Cooke
        • Aug 2012
        • 570
        Originally posted by DEEBS47Chief1991 View Post
        When you get to the point that you have buzzing and tone, you adjust the tone to sound like the Jeep from an episode from MASH. MEEP-MEEP.
        That made me laugh! I overhauled mine not long ago and that's exactly how it sounds! I was thinking the 'Road Runner' but the jeep from MASH is better.
        "the post insulators but that could be fabricated with a grommet or other plastic tube. However, be mindful of heat, petroleum, and vibration when fabricating motorcycle parts".
        My insulators fell apart on disassembly, so I used some PEEK and machined some new ones. Probably overkill, but I had it already and it worked just fine...
        • eddiepanhead
          • Jan 2007
          • 171
          Thanks again for all the help. Got it to make noise. Now have to dial it in
