6V Delco Remy Horn - need help
  • eddiepanhead
    • Jan 2007
    • 171
    Have an original 6v horn on my 47 FL. Horn doesn't work when power and ground applied to posts. I have continuity between the posts. I opened the horn to look for anything obvious and nothing jumped out at me although Im not very familiar with its operation. The posts are insulated from the housing and test that way.
    Any info or ideas on what to look for appreciated. Also, what does the adjustment screw on back do? Is that for adjusting tone?
    Thanks!
  • DEEBS47Chief1991
    Living The Dream
    • Jan 2023
    • 1256
    Here is some info on horn repair. I was able to restore my 47 Indian horn with this procedure.
    • PaulCDF
      • Aug 2019
      • 1416
      Here is link to previous discussion on topic under "Electrical'" forum Essentially same info Deebs has above
      Horn Repair - AMCA Forum
      • eddiepanhead
        • Jan 2007
        • 171
        Thanks for the great info. Will work on it today and report results
        • eddiepanhead
          • Jan 2007
          • 171
          Did some digging per the instructions. I have .3ohms through my windings. When I energized the coil, I don’t get enough magnetic force to pull the core and tit down.
          does anyone make replacement parts for this horn? During disassembly the terminal insulators on both sides of the housing disintegrated.
          any thoughts on how to fix the coil?
          • DEEBS47Chief1991
            Living The Dream
            • Jan 2023
            • 1256
            As long as you are measuring .3 ohms and not an open circuit, the magnetic force should be operational. Your adjustments are probably way off. It won't budge if its adjusted wrong.
            You can energize it and pick up a steel nail to test the magnet. Be mindful of your battery. This is basically a short circuit and will drain the battery fast so make sure to re-charge. Also, if your battery is old and low amperage (NOT voltage but load tested-amperage), the horn may not function correctly.
            • eddiepanhead
              • Jan 2007
              • 171
              Thanks for the coaching! Will hook barely to charger and start messing with the large center adjustment. When I energize the coil, I get a light magnetic attraction, not super strong.
              • DEEBS47Chief1991
                Living The Dream
                • Jan 2023
                • 1256
                Eddie, not sure how you are going about this but you will need to take the horn apart carefully and clean it up which includes cleaning the point contacts gently with fine 600 sandpaper and then polishing the contacts with 1500. My horn was missing the gasket and I had to make one. The gasket ensures that it is sealed from water and sets up the correct end play. There are two tone adjustments. The large center which gets it "in the ballpark" and the small screw/lock adjustment to adjust tone. Be advised that it changes tone from being on the workbench to when it's bolted back on the bike and may need a fine adjustment when its finally installed.
                ezgif-255dd523316b8718.jpg ezgif-25e986a8038f550e.jpg ezgif-27b2cfcf220d1877.jpg
                • DEEBS47Chief1991
                  Living The Dream
                  • Jan 2023
                  • 1256
                  • DEEBS47Chief1991
                    Living The Dream
                    • Jan 2023
                    • 1256
                    • DEEBS47Chief1991
                      Living The Dream
                      • Jan 2023
                      • 1256
                      Make sure when you re-assemble the parts that the tabs line up. Remember, nothing moves unless the points are clean. You need the clean point contact in order to complete the circuit. Heavy sandpaper will ruin the finish of the points so be careful.
                      • DEEBS47Chief1991
                        Living The Dream
                        • Jan 2023
                        • 1256
                        By the way, the weak magnetic situation that you are describing sound like dirty contact points. Not enough current is passing through them to "light" the coil up.
                        When you get to the point that you have buzzing and tone, you adjust the tone to sound like the Jeep from an episode from MASH. MEEP-MEEP.
                        • PaulCDF
                          • Aug 2019
                          • 1416
                          NICE Tutorial Deebs!
                          • DEEBS47Chief1991
                            Living The Dream
                            • Jan 2023
                            • 1256
                            Thanks, I hope it helps.
                            • eddiepanhead
                              • Jan 2007
                              • 171
                              Thanks DEEBS! pics and info appreciated. What material did you make the gasket out of? My horn doesn't have a gasket either. I assume it goes between the diaphragm and the body? I also see what looks like rubber under the studs that pass thru the body, did you make those? My horn has some sort of cardboard insulator that is deteriorated.
